Old 01-04-2021, 07:55 PM   #1
Ziggster
Default Generator Pulley Missing Coolaing Vanes
I had my generator and starter rebuiktca few weeks back, and now just noticed that 3 of the 8 cooling vanes on the back of the pulley have broken off. Is this serious enough in to affect the cooling performance? Of so, I’m wondering if I can add enough brazing rod to rebuild them.
Ziggster is offline   Reply With Quote
Old 01-04-2021, 09:43 PM   #2
flathead48
Default Re: Generator Pulley Missing Coolaing Vanes
I would be concern with balance and cooling. If it were mine I would replace it.
flathead48 is online now   Reply With Quote
Old 01-04-2021, 11:30 PM   #3
Charlie ny
Call VanPelt or Third Gen....I'm sure if you send a photo they'll have what you need.
Charlie
Old 01-05-2021, 07:17 AM   #4
51woodie
51woodie's Avatar
With three blades missing, depending on their relative location to each other, cooling isn't your main problem. Think of the speed the generator turns at, and unless those missing blades are equally spaced, the generator will shred itself due to vibration. JMO
51woodie is offline   Reply With Quote
Old 01-05-2021, 08:32 AM   #5
Ziggster
Thanks. Honestly, I didn’t even think of the balance aspect of things. I guess I’ll just have to order one.
Old 01-05-2021, 11:45 AM   #6
19Fordy
19Fordy's Avatar
Wonder what caused those vanes to break off? In any case, you don't
want shrapnel flying into your hood and radiator or YOU.
Old 01-05-2021, 06:51 PM   #7
G.M.
I would say they broke upon installation. G.M.
www.fordcollector.com
Old 01-05-2021, 07:17 PM   #8
38bill
38bill's Avatar
Dropped?
38bill is offline   Reply With Quote
Old 01-05-2021, 07:40 PM   #9
Ziggster
I have no idea how they broke. Purchased the engine back in 2018 and it was pieces. I never really looked at it prior to bringing it to the shop to have it rebuilt. I'm a bit surprised they would have rebuilt it with the missing vanes.
Old 01-05-2021, 08:42 PM   #10
JSeery
JSeery's Avatar
I would check with the shop and see what they have to say.
Old 01-06-2021, 09:38 AM   #11
19Fordy
19Fordy's Avatar
Is it a cast pulley or stamped steel?
Old 01-06-2021, 10:51 AM   #12
Ziggster
It's the cast one. I’ll try to upload some pics from my iPhone.
Old 01-06-2021, 11:35 AM   #13
Ziggster
Pics.
File Type: jpg 354102FF-EF10-419F-9715-1EBB445201A0.jpg (15.2 KB, 65 views)
Old 01-06-2021, 11:37 AM   #14
Ziggster
Another pic.
File Type: jpg C2BC75ED-8F35-4445-99D4-7310FA2CD7C4.jpg (17.1 KB, 49 views)
Old 01-06-2021, 12:37 PM   #15
19Fordy
19Fordy's Avatar
Someone may have used the vanes as a fulcrum to lift the generator up higher for increased belt tension. Or, worse yet, tried to use vanes as a leverage point to rotate the crank.
Old 01-06-2021, 01:50 PM   #16
my4dv8
That pulley needs to go in file 13 . Post on the wanted listing for a new one.
my4dv8 is offline   Reply With Quote
Old 01-06-2021, 03:09 PM   #17
19Fordy
19Fordy's Avatar
Yes, it's been "pulled" too far.
Old 01-06-2021, 03:27 PM   #18
STEVE O
STEVE O's Avatar
Or to hold the pulley from turning when taking the nut off during disassembly? Steve
STEVE O is offline   Reply With Quote
Old 01-06-2021, 03:40 PM   #19
Ziggster
There is no nut on the shaft. I think the pulley is threaded onto the shaft.
Old 01-06-2021, 03:41 PM   #20
Aarongriffey
Good chance the rebuilder might have another pulley laying around.
Aarongriffey is offline   Reply With Quote
