Old 09-29-2015, 10:02 PM   #1
Kohnke Rebabbitting
Default O.T. Just got done with some Hercules Rods.
Here are some new pictures of some Hercules rods from Ca.
These were insert bearing rods that they could not find the inserts for any more.
So we pour them solid.
Thanks,
Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 09-29-2015, 10:08 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: O.T. Just got done with some Hercules Rods.
Nice work.
I think I see a shim in the rod. Did you use shims for future take up?
Old 09-30-2015, 12:31 AM   #3
Kohnke Rebabbitting
Ya, Tom, I always use .006 thousandths.
Herm.
Old 09-30-2015, 04:39 AM   #4
SAJ
SAJ's Avatar
Great looking job Herm. How do the big ends get their oil?
SAJ in NZ
SAJ is offline   Reply With Quote
Old 09-30-2015, 10:11 AM   #5
Kohnke Rebabbitting
SAJ in NZ
They are pressure, Mr. SAJ, so they didn't have any grooves either.
Thank's
Herm.
Old 09-30-2015, 10:15 AM   #6
Jim Huseby
Jim Huseby's Avatar
What year and series is that Hercules?
Jim Huseby is offline   Reply With Quote
Old 09-30-2015, 10:21 AM   #7
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Nice work. Did they still have the worn-out inserts? If so, why not just re-pour the shells and bore them?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-30-2015, 10:41 AM   #8
Will N
Will N's Avatar
How do you take the cap off with the babbit solid like that?
Will N is offline   Reply With Quote
Old 09-30-2015, 11:23 AM   #9
Kohnke Rebabbitting
Jim, I don't know the year, the owner said, but I don't remember, if you want to know, I could ask again.
The series is WXL C.
Thank's
Herm.
Old 09-30-2015, 12:10 PM   #10
Kohnke Rebabbitting
Brent, the reason we don't normally don't redo the old inserts is, when the insert is new, they are a formed good, tight fit to what ever shell. You just size the hole in the rod to what ever size it calls for.
When you repour, the ends of the inserts will move in to each other, and they have to be spread back to a formed fit, and that is not always possible to get a 100% fit again.
So if you have a small spot, say the size of the end of your little finger that is away from the shell wall about a half a thousandths, the crank will either bring it into shape and it stays, or it keeps pushing it in and out until the babbitt fractures.
So when poured solid, no problems of that nature.
Now, main bearings, you don't have that worry, as the crank just turns in a circle.
But we have done rod inserts, when the owner won't take no for an answer, but if they come apart, I would't warranty, although we have never had a bad bearing ever come back.
Thank's
Herm.
Old 09-30-2015, 12:16 PM   #11
Kohnke Rebabbitting
These are Jig poured Rods Will, so they were not poured in one piece.
When I say poured solid, I am saying that there is no insert, and the babbitt is stuck to the Rod.
Thank's
Herm.
Old 09-30-2015, 02:43 PM   #12
SAJ
SAJ's Avatar
Once again thanks so much for sharing your knowledge with us Herm. There certainly is a lot to know about poured bearings!
SAJ in NZ
Old 09-30-2015, 03:47 PM   #13
Dave in MN
Dave in MN's Avatar
Thanks for sharing Herm! Always interesting!
PS: You did my CC Pickup mains about 14 years ago...I don't drive it much but it just keeps running good when it does! Thanks!
Good Day!
Dave in MN is offline   Reply With Quote
Thread Tools
Display Modes
