Old 11-21-2010, 11:51 AM   #1
JunkOSC
Default Who's running a Mitchell Transmission?
I see Mitchell makes a synchronized transmission that has gears cut with a 15% higher ratio for better top end performance. What does that mean in real life? Would you say that adds 5 mph to performance?
Thanks in advance!
Tim
JunkOSC is offline   Reply With Quote
Old 11-21-2010, 12:29 PM   #2
Renorust
Renorust's Avatar
Default Re: Who's running a Mitchell Transmission?
I have been running a Mitchell synchro transmission this summer and can report the following:
* There are three ratio options - original, 2nd @ 15% higher and reverse 2nd and 1st @ 15% higher. Top end speed will remain the same for all options. Acceleration from lights and in traffic is improved with the higher ratio 1st and 2nd and by synchro assissted shifting.
* The main feature is synchro for 2nd and 3rd. Shifting is a breeze both up and down as you would expect. External box is stock so no unusual views when you look under the car or in the cabin.
* Installation was as explained in the literature that comes with the unit. No problems or special fabrication required.
* On road performance live up to the claims. Quick, smooth shifts, no jumping out of gear on acceleration or decelleration, no oil leaks. Two year warranty.
* Dealing with Mitchell was straightforward. On time delivery. Good crating of the unit. No surprises, none of the "oh by the way..." stuff.
* Give them a call if you have further interest and get the story first hand.
Renorust is offline   Reply With Quote
Old 11-21-2010, 02:14 PM   #3
Dick So. Cal.
I, too, purchased a Mitchell tranny for my Cabriolet. The reason was is that my wife could not get the non-syncro shifting thing down pat.
I bought the 15% low and second and the ratios are great. High is the same, 1:1.
I have driven non-syncro for 50 years and I kinda miss the mind-game, if you will, of driving the original set-up smoothly. It was a challange to do it correctly and I liked the challange.
The new set-up is a breeze. No challenge. Get in and drive. I do have to admit that on a recent Palos Verdes CA road rallye, the syncros made it easy in the hills and the gear ratios helped a lot.
It was a no brainer to install. Straight removal and installation. Easy.
All in all, I say go for it!
Dick Wyckoff
Dick So. Cal. is offline   Reply With Quote
Old 11-21-2010, 07:57 PM   #4
Glenn C.
Glenn C.'s Avatar
We have two Model A's with Mitchell transmissions with no problems. Do like that synchro between 2nd and 3rd.
Glenn C. is offline   Reply With Quote
Old 11-22-2010, 08:16 AM   #5
Cajun
I am running a Mitchell synchro in line with a Mitchell OD in a speedster. Works great! This combination allows for a shift from second as high as 50 MPH.
Cajun is offline   Reply With Quote
Old 11-22-2010, 04:15 PM   #6
Glenn of northport
Glenn of northport's Avatar
Red face Re: Who's running a Mitchell Transmission?
I have 2 Mitchel they are easy to drive down shifting is great ,I plan on giving my model A cars to my grandkids this will make them easy to drive.
Glenn of northport is offline   Reply With Quote
Old 11-22-2010, 04:53 PM   #7
dr.j
So am I correct to assume from 1st to 3rd gear no double clutch required and no double clutch from 3rd to 2nd?
Can I assume you must double clutch to 1st from 2nd gear if moving or be stopped to go into 1st gear?
Dave A Jamieson
Portland, ON
Canada
1928 Tudor
dr.j is offline   Reply With Quote
Old 11-22-2010, 05:59 PM   #8
JunkOSC
Thanks guys for the info. I have been doing more research, I think I'm going to go this my stock tranny and install the Michell OD. They seem to be very reliable and work well under stock conditions.
My goal here is on the weekends to be able to take the car on the freeway so I can get across town to see friends/family and attend events. The foot print of the metro Phoenix area is HUGE and keeps getting larger.
br,
Tim
Old 11-22-2010, 06:51 PM   #9
30Tudor
30Tudor's Avatar
If you install the Overdrive, you can use it to more easily downshift your stock transmission as well. Its a bit of work with the hands as you put the OD in neutral when you shift between third and second gears.
30Tudor is offline   Reply With Quote
Old 11-22-2010, 07:59 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
Correct!
Old 11-25-2010, 06:46 AM   #11
jerry shook
I have one in my 30 coupe best thing i have done . GREAT.
jerry shook is offline   Reply With Quote
Old 11-22-2014, 07:45 PM   #12
Cabrioletdave
Is your Mitchell transmission still running great?
Cabrioletdave is offline   Reply With Quote
Old 11-22-2014, 08:07 PM   #13
Ford1931
Ford1931's Avatar
I put the 15% first and second gear Mitchell in my slant window four door. I like the easy upshift and downshift and use the motor more and the brakes less. I will be putting the Mitchell 26% overdrive in over the winter with the 3.54 gears in the rear end. I have a touring motor with the Burlington crank, Stipe cam and Snyders 5.5 head. I am hoping the combination will give me more flexibility on various roads, keep the rpms down and have the ability to drive on the interstate should I want.
Ford1931 is offline   Reply With Quote
Old 11-22-2014, 08:39 PM   #14
bettlesr
bettlesr's Avatar
You should not have to double clutch from 1st to 2nd as both 2nd and 3rd have synchros
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 11-22-2014, 09:09 PM   #15
JohnLaVoy
JohnLaVoy's Avatar
On the Summer Tour last year one of the participants broke their original transmission the first day. We called Mitchell and they brought a syncro trans to the convention and Steve Mitchell (pictured) even helped with the install. Nice transmission and great people to deal with.
JohnLaVoy is offline   Reply With Quote
Old 11-22-2014, 10:18 PM   #16
pgerhardt
pgerhardt's Avatar
I am planning on putting a mitchell transmission in my 29 tudor. While I know I can buy one through the big 3 parts dealers, I would rather deal directly with the Mitchells rather than have them have to share the profit with a reseller. Does anyone have an email address or phone number for them.
Thanks in advance.
pgerhardt is offline   Reply With Quote
Old 01-26-2015, 01:10 PM   #17
arnhemmer
Mitchell manufacturing 1157 Parker St. Colusa Ca 95932 1-800-859-2088
arnhemmer is offline   Reply With Quote
Old 01-26-2015, 02:11 PM   #18
CarlG
CarlG's Avatar
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-27-2015, 12:11 PM   #19
modelAtony
modelAtony's Avatar
Mr John, that looks like one of them TEAM ROPIN RODEO COWBOYS there. Great bunch of people, Late mr. Glenn, wife miss sue, son Stephen, wife cindy and their son Spencer PRCA TEAM ROPER like Grand pa, and dad. have fun modelAtony tony white Lafayette, LA
modelAtony is offline   Reply With Quote
Old 10-29-2015, 05:19 PM   #20
ttoldcarbuff7
Everyone seems happy with the Mitchell, but is there anyone who wishes they didn't swap out to a Mitchell? I am just trying to get a feel before dropping big dollars.
ttoldcarbuff7 is offline   Reply With Quote
