Old 07-14-2019, 09:23 PM   #21
!!!RIOT!!!
!!!RIOT!!!'s Avatar
Default Re: Calling all Transmission Gurus
I had a hell of a time with my '52 trans because I refused to read the directions and thought "Well, assembly is the reversal of disassembly so..." After installing the cluster and having no way to get the input shaft into the case and punching the cluster shaft out and hearing all those carefully placed pins go all over the case, I pulled out the shop manual.
Mike J has it right though, that's the method I finally used and it worked perfectly. I just wish I had saved myself a couple of hours and done it that way the first time.
!!!RIOT!!! is offline   Reply With Quote
Old 07-14-2019, 09:55 PM   #22
cas3
huh x2 !
Old 07-15-2019, 02:25 AM   #23
Mart
Mart's Avatar
I see your huhs and add a wtf.
Old 07-21-2019, 11:36 AM   #24
Bob's '53
Thanks to the suggestions here, info from Mac at VanPelt and a transmission guru on the FTE (Ford Truck Enthusiasts) Forum, my Trans. is all back together.
Even has 3 forwards, a reverse and a neutral!!
Won't be road tested for a while, but all seems well!!
Thanks Again!!
Bob's '53 is offline   Reply With Quote
