Old 06-16-2021, 07:07 PM   #21
aussie merc
aussie merc's Avatar
Default Re: Major brake adjustment procedure request
Factory manuals work with new parts so new shoe/lining and drum . Factory doesn't recognise any wear however minor .A worn drum has a larger dia so you need a thicker lining to compensate for the wear ie drum has .050 thou wear lining needs to be 0.25 thicker to compensate shoes are ground to set the correct clearance . but you still need to install the shoes correctly to achieve this hence the anchor pin adjustment
aussie merc is offline   Reply With Quote
Old 06-18-2021, 05:48 AM   #22
Marshall V. Daut
Mike42 -
Is this the power bleeder you used? https://www.summitracing.com/parts/m...iABEgL-YPD_BwE
The left front drum now fits correctly and spins after the outer nut has been tightened. Problem solved.
Marshall
Marshall V. Daut is online now   Reply With Quote
Old 06-20-2021, 04:31 AM   #23
mike42
mike42's Avatar
Marsh…….yes that’s what I bought. I also answered your PM but I’ve been traveling and be home Monday and I’ll send you the photo of adapter I made up. What’s ur email address as I’ve never had success posting photos here sorry !
Mike
mike42 is offline   Reply With Quote
