Old 05-02-2012, 09:22 PM   #21
JBohannon
Default Re: Timing
I have timed my A without much problem. I was a little suprised how hard it was to turn engine over with even the plugs out. I could not turn just the crankshaft pulley. I had to use the fan. Is this normal. Joe B.
JBohannon is offline   Reply With Quote
Old 05-02-2012, 11:04 PM   #22
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Timing
Joe,
Chief always said, "The easiest way is the best way if it does the job properly!" Since your engine turns a little hard, maybe that's a good sign that it's not a "loosey-goosey" old WORN out chunk of iron! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-03-2012, 06:56 AM   #23
RonC
RonC's Avatar
Default Re: Timing
A couple of common reasons why some may have trouble hand cranking the engine could be misalignment of the engine transmission assembly with the frame or worn crank nut or crank handle.
RonC is offline   Reply With Quote
Old 05-03-2012, 10:07 AM   #24
Franchise_24
Franchise_24's Avatar
Default Re: Timing
Thanks for all the good info from everyone. We are going to try to time it on Sunday and I'll let everyone know how it goes.
Franchise_24 is offline   Reply With Quote
Old 05-03-2012, 08:19 PM   #25
Mort
Default Re: Timing
The crank is a little hard to turn normally but if you do it a little at a time (slowly) the compression with ease and you should be able to do it without a problem.
Mort is offline   Reply With Quote
Old 05-03-2012, 11:05 PM   #26
rollingsculpture
rollingsculpture's Avatar
Default Re: Timing
actually does not sound like a timing problem but more likely running too lean on the air/fuel adj screw... is it set 1 1/2 turns out ? or???
Rust and roll will never die
rollingsculpture is offline   Reply With Quote
Old 05-04-2012, 09:28 AM   #27
Franchise_24
Default Re: Timing
Yah I've played with that at different settings and it made no difference. I really am hoping it is just timing.
Old 05-04-2012, 10:34 AM   #28
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Timing
I agree that the problem is more than likely a running lean condition. The air fuel adj. screw on top of the carb, only controls the idle circuit. If the idle speed adjust screw isn't set for a low idle speed, the idle circuit won't kick in and the air adjust screw will have NO effect on idle.
Vacume leaks cause a lean condition. The engine depends on vacume to draw the fuel air mix, up the manifold to the combustion chambers.If there is a vacume leak the engine will be drawing more air which leans the mix. sometimes opening the GAV will help compensate by richening the mixture. If the vacume leak is severe enough, nothing short of fixing the leak will help at all. If a pot metal carb is used, the first place that I would look is where the carb meets the intake manifold. The second would be the manifolds and condition of the seal between the manifolds and block. A lot of cars have warped and cracked manifolds caused from running with retarded timing or driving with the spark lever half way up the quadrant. Torqueing and over tightening the manifolds is also a major cause of warped and cracked manifolds . WD 40 is NOT good to use when checking for vacume leaks. The formulation of WD 40 has been changed and it is no longer flamable. The test fluid or gas needs to be flamable to show an increas in engine speed when testing. Starting fluid or carburetor cleaner sprayed in the suspected leak areas is the best vacume leak test product.
Old 05-04-2012, 12:23 PM   #29
Franchise_24
Default Re: Timing
Thanks for the info. I know the few times I've had it running I've had to turn the choke rod about all the way open to get it to start, and it takes minutes upon minutes to get it to finally start. Does that still sound like a vacuum problem?
Old 05-04-2012, 12:27 PM   #30
tdlmomowers
tdlmomowers's Avatar
Default Re: Timing
Recheck your carb. mounting. A mounting bolt that is too long can interfer with the carb. housing and not allow the carb. to tighten against the manifold. Also make sure you don't have a vacuum leak at the fitting where the line went for the vacuum wipers. Manifold bolts that are loose can also cause the engine to run lean.
tdlmomowers is offline   Reply With Quote
Old 05-04-2012, 01:12 PM   #31
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Timing
If it takes minutes to start, then you have a real problem, because the engine should start within a few compressions. You need good compression, good spark at the right time, and gas and air. If you pull the choke for a couple compression strokes then gas should drip or run out the carb intake. If not, then you need to see why.
Turn the key on and push the starter rod with your hand while you hold the coil wire 3/8" from a head nut to check for a hot blue spark.
Use a compression tester to check for good compression and within 10% on all cylinders.
Old 05-04-2012, 01:22 PM   #32
Purdy Swoft
Default Re: Timing
Having to open the GAV way up to get it to run is a real indication of a vacume leak. What carburetor are you useing??? If it is a pot metal carb, I would remove the carb and check for flatness where it meets the intake manifold. usually filing or sanding will help correct the problem. I use the copper clad carb to manifold gasket. The copper gasket is thicker and will squeeze down when tightened and better seal a less than perfect carburetor flange. If a leak is determined to be the gasket between the manifold and the block, I have found thaat the copper clad 1931 style gasket is the best choice. The 31 style gasket is wider and will have a better chance of sealing the gap if you have a slightly sagging manifold assy. You will also need to lay a straight edge lengthwise across the ports of the manifold to check for flatness. If the manifold assy is warped it can be plained.
On the other hand, if no vacume leak can be found, I would check points gap before messing with the timing. If the points gap has closed it will cause similar problems. I set my points at .022 but anywhere from .018 to .022 will work. Its best not to mess with the timing until other avenues are explored. There is a lot of confusion about timing procedure. When checking the timing, watch the rotor tip. When the timing pin drops in place, the trailing edge of the rotor tip should line up with the number one plug wire contact in the distributor cap body with NO clockwise backlash. Counter clockwise backlash will probably be present but will have no effect on timing.
If you can follow what I am saying, it should solve your problems one way or the other. Just one other thing. If you are having to use ethanol adultrated gas and it has been in the tank for a few weeks, this may be the problem. Good luck and keep us posted.
Old 05-04-2012, 02:07 PM   #33
mothy
mothy's Avatar
Default Re: Timing
Thinking of sfaety, I have to put another angle to this statement.
When I was involved in the MG Midget world there were a few serious under bonnet/hood fires caused by people using carb cleaner to find air leaks. Naturally any flammable substance will ignite when sprayed near a very hot manifold.
It is my understanding is that WD40 or some other non volatile aerosol proves the air leak, by blocking the leak temporarily before it evaporates away. The theory is that the rpm rises, due to the mixture becoming richer while the air leak is blocked.
Roly
mothy is offline   Reply With Quote
Old 05-04-2012, 02:28 PM   #34
jan bogert
jan bogert's Avatar
Default Re: Timing
Blessyouboys, with the plugs out, turning the fan doesn't do any damage to the fan, or any thing else.
jan bogert is offline   Reply With Quote
Old 05-04-2012, 03:06 PM   #35
Purdy Swoft
Default Re: Timing
[QUOTE=mothy;419459]Thinking of sfaety, I have to put another angle to this statement.
Roly[/QUOT
I agree that carburetor cleaner and starting fluid are flamable. I wouldn't test for vacume leaks if the manifold is red hot . Common sense is needed, whatever!! The purpose of the flamable liquid is, when the vacume leak draws it into the combustion chamber, engine speed will increase and show where the leak is. WD 40 just won't work in this case period. WD 40 will not temporarily block the leak, it will just be drawn in to the cumbustion chamber just like air and will make NO difference in engine speed.
Old 05-04-2012, 03:12 PM   #36
BILL WILLIAMSON
Default Re: Timing
Stethascope with open hose is GOOD! Yes, I repeat a lot!
Repetition is the MOTHER of learning & the FATHER of boredom! Bill W.
Old 05-05-2012, 09:40 AM   #37
Blessyouboys
Blessyouboys's Avatar
Default Re: Timing
I respectfully disagree. The fan was not designed to be used as a lever to turn the motor over.
Blessyouboys is offline   Reply With Quote
Old 05-05-2012, 09:44 PM   #38
BILL WILLIAMSON
Default Re: Timing
Were you an acquaintance of the DESIGNER????
Like, was our pinkie designed to clean our nose boogers? It's called IMPROVISING!
Show me one real mechanic out there who has NEVER turned an engine by it's fan, get real!
Bill W.
Old 05-05-2012, 09:54 PM   #39
ford1
Default Re: Timing
Hey Bill, hes right it was not designed to turn over the engine,BUT it works so why not use it?, i use that method to turn the engine for some settings, like setting points and static setting the timing, my theory is if it works, use it, How is your wife? comforable at the least i hope,
ford1 is offline   Reply With Quote
Old 05-06-2012, 12:54 AM   #40
BILL WILLIAMSON
Default Re: Timing
I coud make a living, just traveling around the country, settin' folks timing & pin pointing vacuum leaks! Bill W.
