01-05-2021, 01:37 PM | #1 |
Vikky Hardware
Can any one post a pic or at least tell me what bolts or screws are in the rear fender well that hold body to wood sill. There are 3
TIA |
01-06-2021, 09:49 AM | #2 |
Re: Vikky Hardware
The screws are flat & slotted head wood screws, #12 and 1" long. I broke the heads off trying to remove the original screws, so I moved the screw locations a bit with a patch panel.
By the way, if you look hard at the picture, you can see the original paint on my 190A. The wheel wells were originally painted Ford Maroon and over-coated with black.
Bob Bidonde |
01-06-2021, 10:55 AM | #3 |
Re: Vikky Hardware
Thanks Bob, that's what looks like is there or whats left of them. The holes are a bit bigger now so I will have to close them up.
01-06-2021, 03:46 PM | #4 |
Re: Vikky Hardware
Here are pictures of the screw in the bottom of body rear fender area. This is the first time that the screw has been removed from my Victoria.
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
01-07-2021, 07:52 AM | #5 |
Re: Vikky Hardware
Thanks!
12-19-2022, 11:25 PM | #6 |
Re: Vikky Hardware
Alan Baron 1931 Model A Victoria 1939 Pontiac Quality 6 Sold - 1940 Sedan Delivery |
12-20-2022, 03:14 PM | #7 |
Re: Vikky Hardware
You can use a hollow core drill bit to get the screw out then epoxy in a piece of hardwood dowel. Sand it flush and use the stock holes with no repair showing.
https://www.tognar.com/hollow-core-d...EaApY5EALw_wcB |
12-21-2022, 04:30 PM | #8 |
Re: Vikky Hardware
I enjoyed reading this thread. It shows the need for attention to detail, detail which was not performed on my Victoria. The quarter panels on my car have the damaged holes you describe but the problem was ignored and covered with underbody paste. The damage is further covered by installing the wheels! But, I bought the car anyway. The paint job was very good and the motor was recently rebuilt. Not much more I can say. I am disgusted every time I have to remove the wheels. Ed
