04-23-2018, 09:02 AM | #1 |
Sagging 1 1/2 in rear driver side
My 28 A Tudor is sagging by 1 1/2 inch. Where would be a good place to look first?
Thanks |
04-23-2018, 09:19 AM | #2 |
Re: Sagging 1 1/2 in rear driver side
Shackle may have gone over center? Check to see if the left and right are in the same relative position.
John |
04-23-2018, 09:22 AM | #3 |
Now long has it been this way?
If you push car up on drivers side, will it go back to level and stay there until you drive or sit in it? |
04-23-2018, 09:22 AM | #4 |
I think it is also known sometimes as the Bachelor's sag! My 1928 Tudor and 1928 Roadster are the same.
Cars used over many years with just the driver using it. |
04-23-2018, 01:34 PM | #5 |
Tony do you know the color names of your car?
04-23-2018, 01:35 PM | #6 |
04-23-2018, 05:58 PM | #7 |
You are a smart person! Yes. What should I look for?
Thanks! |
04-23-2018, 08:10 PM | #8 |
What are the names of the colors. It looks like mine and I am trying find out what they may be.
04-24-2018, 01:12 AM | #9 |
I can't remember off-hand Dan. I will try and research them for you.
04-24-2018, 06:14 AM | #10 |
04-24-2018, 06:46 AM | #11 |
Thank you. I will too. Nice looking car you have!
04-24-2018, 08:52 AM | #12 |
Colors: Chicle Drab lower, Copra Drab upper.
http://www.mafca.com/gallery_colors.html Sagging: Turn the springs around. |
04-24-2018, 09:30 AM | #13 |
The flow of this thread makes no sense to me
04-24-2018, 10:17 AM | #14 |
Remember to ALWAYS follow the instructions, on your MEDS!
"Dr" Bill W.
04-24-2018, 12:44 PM | #15 |
Both. Sorry.
04-24-2018, 12:45 PM | #16 |
My big problem is the sagging. Yes, it returns to normal when you pick up driver front. What can cause that?
04-24-2018, 12:51 PM | #17 |
Sticking spring shackles, old grease blocking new grease going in, lack of grease, etc.
04-24-2018, 01:17 PM | #18 |
Also 90 year old springs.
Think of what your favorite chair would feel like after you had been sitting in it for 90 years watching TV and drinking beer. Either take them off and refurbish, or replace with new springs. If it were my car. I wouldn’t waste time refurbishing, I would get new springs. |
04-24-2018, 03:36 PM | #19 |
Thank you WHN. Very helpful.
04-25-2018, 10:11 AM | #20 |
Or, see post #12 above
