Old 11-16-2016, 02:18 PM   #1
Squally
Squally's Avatar
Default Valve Cover has Extra TUbe
The valve cover on our 1930 car has an extra tube that looks like it might be an additional oil return tube. Has anyone seen this before or know what it is?
Squally is offline   Reply With Quote
Old 11-16-2016, 02:41 PM   #2
AL in NY
AL in NY's Avatar
Default Re: Valve Cover has Extra TUbe
Looks like someone added the tube to supply more oil to the valve chamber. Don't understand why because all the output of the oil pump goes to the valve chamber to begin with. The only thing that tube does is redirect the oil to the rear of the valve chamber.
AL in NY
AL in NY is offline   Reply With Quote
Old 11-16-2016, 02:46 PM   #3
CarlG
CarlG's Avatar
The engine that came with my pickup had a tapped hole in the valve cover in that exact location, but it just had a plug in it. Never knew just what it was for. It does seem strange that it would be taking freshly pumped oil and dumping it in the rear of the valve chamber.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-16-2016, 02:47 PM   #4
tinkirk
tinkirk's Avatar
looks like they are supplying the back of the valve chamber so it gets oil sooner than the way it is designed
which i don't think is a bad thing because the way the oiling system is designed the oil flows forward and floods the chamber before the rear bearings get oil
tinkirk is offline   Reply With Quote
Old 11-16-2016, 03:10 PM   #5
C26Pinelake
another backyard mechanic that thought he was smarter than Henry and crew! Wayne
C26Pinelake is offline   Reply With Quote
Old 11-16-2016, 03:39 PM   #6
George Miller
George Miller's Avatar
It could have been a oil filter return line, from the old days.
George Miller is offline   Reply With Quote
Old 11-16-2016, 05:12 PM   #7
PC/SR
I wonder if there might be a distribution tube on the inside, spraying oil onto the valve stems/lifters, or into the other 2 wells?
PC/SR is offline   Reply With Quote
Old 11-16-2016, 05:54 PM   #8
tinkirk
tinkirk's Avatar
Now thats a good point could very well be we've done that with race motor
Old 11-16-2016, 06:03 PM   #9
bunnyc
bunnyc's Avatar
The valve cover on my '30 engine has the plug shown in the photo. Looks like it could be 1/8" NPT.
bunnyc is offline   Reply With Quote
Old 11-16-2016, 06:08 PM   #10
tinkirk
tinkirk's Avatar
Now I would like to see the inside of the cover and the chamber itself to see if they blocked off the original oil feed.
Old 11-16-2016, 06:12 PM   #11
Gold Digger
I bought a combine engine back 51 years ago to use in a car that had an oil filter that was connected in the same places. An old mechanic told me to get rid of it that it was trouble looking for a place to happen. So I took it off.
Gold Digger is offline   Reply With Quote
Old 11-17-2016, 02:57 PM   #12
wensum
wensum's Avatar
It could also be a conversion to mains pressure oiling.
That is the take-off point for any conversion to mains pressure.
It's what happens inside the valve chamber that will explain the modification?
Keith
wensum is offline   Reply With Quote
Old 11-18-2016, 10:13 AM   #13
Bob Bidonde
Bob Bidonde's Avatar
That tube short circuits the oil output of the pump. It does fill the rear oil dams before the front ones.
Bob Bidonde
Old 11-18-2016, 05:49 PM   #14
40 Deluxe
Until the cover is pulled we don't really know what that line is for.
Old 11-18-2016, 06:21 PM   #15
Squally
Squally's Avatar
I pulled the cover today. There's nothing on the other side.
