01-07-2024, 03:22 PM | #1 |
Front turn signal solution on 36
Just sharing some info as I finish up details on my 36. I needed a front turn signal solution and preferred LED and inconspicuous. Found these lights, I think on Amazon; the measurements provided were close so I took a chance and bought a pair. They could not have fit any better. See photos for part details and install.
01-07-2024, 04:51 PM | #2 |
Re: Front turn signal solution on 36
do you have item # or any other info for us to find them ?
People post stuff like this but give no info for somebody else to find them. Update: Must have missed that pic ???
48 Ford Conv 56 Tbird 54 Ford Victoria Last edited by paul2748; 01-07-2024 at 07:29 PM. |
01-07-2024, 05:07 PM | #3 | |
Took me about 30 seconds to find, going by the second picture. Click the link BELOW! https://www.truemods.com/side-marker-lights Coop |
01-07-2024, 05:19 PM | #4 |
Easier to see
Making the simple complicated for over 30 years. |
01-07-2024, 05:32 PM | #5 |
PG, good info.
I been looking, not seriously yet , for same size lights with duel color bulbs. Now a days , I try to run a : Clear bulb for a Daytime Running Light & Amber bulb for turn. Stretch |
01-07-2024, 06:05 PM | #6 |
Wish I had hunted a little harder when that need arose. |
01-07-2024, 08:26 PM | #7 |
I used a white/clear backup lens because I did not like the egg yoke look. Then I bent some 5/16 rod and tucked the bulb inside the horm.
Steve in Denver Last edited by Steve in Denver; 01-07-2024 at 08:45 PM. |
01-07-2024, 08:31 PM | #8 |
Steve in Denver |
01-07-2024, 08:36 PM | #9 |
Steve in Denver |
01-07-2024, 08:36 PM | #10 |
thanks coopman, making the pictures bigger worked. I did not know about the yellow box.
Steve in Denver |
01-08-2024, 01:39 PM | #11 |
These 6 volt or 12 volt?
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
01-08-2024, 01:54 PM | #12 |
1157 12v, LED or regular, clear or amber
1154 6v, LED or regular, clear or amber NAPA has them
Steve in Denver |
01-09-2024, 09:56 AM | #13 |
Where did you get the lens?
01-09-2024, 09:59 AM | #14 |
Napa, not sure what number. They are back up lenses for trucks.
I'll go back down there and see if I can find them. Its been a while.
Steve in Denver |
01-09-2024, 10:48 AM | #15 |
I saw some yesterday at Oreillys (Sp? Kragen). Around 7 or 8 bucks.
