10-05-2021, 02:25 PM | #1 |
What are these early hydraulic brakes?
I came across these at the scrap yard recently. They are very similar to a '39-'45 set. However, it's tapered along the area just above the two adjusting cams.
It also is kicked out a bit below the cams similar to Lincoln backing plates. It also bolted to a rear axle with six bolts. Thanks for the input. Last edited by The Lucky Star; 10-05-2021 at 02:31 PM. |
10-05-2021, 02:50 PM | #2 |
Re: What are these early hydraulic brakes?
Yes.
10-05-2021, 05:08 PM | #3 |
The Lucky Star wants to know what are these Backing Plates are off? |
10-05-2021, 06:30 PM | #4 |
possibly 35-41 Studebaker
10-05-2021, 06:50 PM | #5 |
If they were bolted to a rear axle, would it be safe to assume the emergency brake is on the driveshaft/back of transmission?
Botton line: They ain't early Ford. |
10-06-2021, 01:44 PM | #6 |
10-07-2021, 08:14 AM | #7 |
six bolts to the axle indicates high braking load and no park brake lever indicates truck with tailshaft/transmission brake
