Go Back   The Ford Barn > The Archives > Early V8
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default 1950 rear end pinion bearing adjustment
need info on pinion bearing adjustment believ crush washer is required unable to find washer any help appricated thanks all
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
Default Re: 1950 rear end pinion bearing adjustment
There is no crush washer, they appeared in 8" & 9" diffs.
There is a tubular spacer, 8A-4662-B, this can be shimmed or ground to obtain correct preload.
