Old 09-21-2021, 05:35 PM   #1
Merc Cruzer
Merc Cruzer's Avatar
Default Testing a Dwell Gauge
When you are out at a swap meet or garage sale and see a Dwell Gauge, is there any way to test the gauge without a car?
Merc Cruzer is offline   Reply With Quote
Old 09-22-2021, 03:35 AM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: Testing a Dwell Gauge
There is no way that I can think of
Old 09-22-2021, 07:23 AM   #3
big job
big job's Avatar
And then "I have a nice all chromed up maybe Snap on." problem is there is no known battery's available for its weird voltage. so it sits in the draw.
big job is offline   Reply With Quote
Old 09-22-2021, 09:55 AM   #4
1948F-1Pickup
1948F-1Pickup's Avatar
Those are always a "risk" buy. You never can predict how internal
electronic components will age.
I have an Orbit Laboratories light/dwell/tach meter my Dad got
in the early 70's. Still works fine. Nice, because I've seen some pretty
pricey old stuff that didn't.
1948F-1Pickup is offline   Reply With Quote
Old 09-22-2021, 10:21 AM   #5
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
I guess there is a good way A dwell meter is a calibrated volt meter , carry a 9 bolt in a zip lock snd hook it up should have some needle bump from the battery ???
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 09-22-2021, 10:40 AM   #6
Merc Cruzer
Yup, that works.
Thanks
Old 09-22-2021, 11:36 AM   #7
Bored&Stroked
That's a great idea! At least you know that it "might work" . . . depending on whether or not it needs batteries or a power source itself (most do not).
Old 09-22-2021, 03:14 PM   #8
motordr
Next, you might need to figure out a way to calibrate it.
motordr is offline   Reply With Quote
Old 09-22-2021, 04:28 PM   #9
Pete
Pete's Avatar
The setup to calibrate is fairly simple. Just hook it up on an engine alongside a known good meter and see if the two compare the same at various rpm's.
Adjusting the calibration is a whole other can of worms. Usually not cost effective on cheap meters.
Old 09-22-2021, 05:14 PM   #10
Merc Cruzer
That is what started this whole thing. I have two meters, and they don't agree, so now I bought a third one, to see who wins!
Now we know why guys have multiple meters, some marked good and others marked bad, when you go to a garage sale.
Never did find an article on how to calibrate them.
Old 09-22-2021, 08:02 PM   #11
Crankster
Crankster's Avatar
Default Testing a Dwell Meter
If you dig around the intertube pages, you should find what you're looking for. A standard voltmeter can be used to check dwell if you understand what you are looking at, a dwell meter isn't very sophisticated as far as test equipment goes, notice this feature was typically included with simple analog voltmeter/tach units. "Engine Analyzer" they called them. Advertising, I suppose.
Crankster is offline   Reply With Quote
