05-01-2021, 04:10 PM | #1 |
1950 H226 oil pan removal
Has anyone dropped the oil pan on a 1950 ford car with the engine in the car? Engine is 226 flathead 6.
Wondering if it will clear the front cross member.. Thanks, Steve |
05-01-2021, 04:19 PM | #2 |
Re: 1950 H226 oil pan removal
I did on a F1, don't know about a car.
Bruce
Works good Lasts long time |
05-01-2021, 04:27 PM | #3 |
I have a significant amount of oil leaking from the bell housing. I suspect the rear main rope seal may be the culprit. Part of the front cross member had at one time been cut away to fit a large V8, so there is extra room. Just did not know if the pan would clear the crank journals.
05-01-2021, 04:30 PM | #4 |
If it's anything like a V8, it helps a lot if the crankshaft is turned so the counterweights on the front are up.
05-01-2021, 05:03 PM | #5 | |
......about 45º AFTER #1 TDC! DD |
05-01-2021, 05:19 PM | #6 |
Cheers, Jim&Sandy McGregor, IA |
