05-18-2018, 08:12 AM | #1 |
electric wipers 40 pickup
my 40 pu has a single non working wiper and I see speedway sells a universal electric wiper anyone using one in a 40-47 pickup pros and cons.thanks p/s truck has 12v system
05-18-2018, 08:17 AM | #2 |
Re: electric wipers 40 pickup
For a really good wiper setup I would spend some extra money and get the wiper kit made for your truck from Newport Engineering.
05-18-2018, 01:28 PM | #3 |
05-18-2018, 04:52 PM | #4 |
I did a dual wiper conversion on a 41 cab, had to cut the glove box down by half to put the wiper on ps. I think this one came from carpenter or drake. If I had to do over again I would not.
05-19-2018, 07:03 AM | #5 |
05-19-2018, 12:52 PM | #6 |
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS..... http://s818.photobucket.com/home/roglehr/index |
05-20-2018, 06:56 PM | #7 |
Rebuilding an original vacuum wiper may be a simple solution. Kent at Clean Sweep in Redmond OR did one for my '40, and it works great.
05-20-2018, 07:27 PM | #8 |
I used a Speedway unit in my pickup. It works well when I need it. I set it up to stop when the switch is turned off. I like it parked at the cowl. If the built in park feature is used it will park against the center windshield bar.
You are never to old to enjoy your childhood. Forty1fordpickup on the HAMB. Last edited by 41ford1; 05-20-2018 at 07:31 PM. Reason: Fixed spell check. |
05-21-2018, 08:10 AM | #9 |
