11-20-2016, 10:09 PM | #1 |
Electric solenoid on Mitchell OD
Has anyone fitted an electric solenoid and switch rather than the cable system.
If so what was used cheers |
11-21-2016, 01:18 AM | #2 |
Re: Electric solenoid on Mitchell OD
Interesting question. Soleonoids usually work only in one direction, a Mitchell needs to
go two directions. Lets see what others think. |
11-21-2016, 02:05 AM | #3 |
Dodge just realised yes it has to push the gear change lever and pull it maybe needs some type of small electric motor cheers
11-21-2016, 07:19 AM | #4 |
The solenoid on an overdrive is spring loaded so it is electrical to engage and a spring to disengage.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
11-21-2016, 09:02 AM | #5 |
as the electric magnet has more pull after it gets going. I used selonids for power to openers (big wire) and small wire to change gear. Works good |
