Old 08-24-2018, 12:37 PM   #1
rosenkranswa
rosenkranswa's Avatar
Default Weird Question
Weird question, I'm doing some work on a friends 28 Model A Phaeton to get it ready to sell. Pretty good shape, basic maintenance items and lots of TLC. His crank nut on the engine doesn't line up with the crank bearing so I can't engage the handcrank to set the points and timing (now I know why his dad didn't have a crank for it).
Any ideas on how to turn the crank other than bumping the starter?
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'38 Columbia Girls bike (WWII)
'40 Elgin Boys bike (WWII)
'42 Super Deluxe Tudor
'42 Willys MB Jeep
'43 Willys MBT Trailer
'43 M3A4 Hand Cart
'43 Harley Davidson 42WLA with sidecar
rosenkranswa is offline   Reply With Quote
Old 08-24-2018, 12:44 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Weird Question
You could buy a ratchet nut wrench to turn the engine OR you could try to determine why the crank does not line up. I have a tool box in the way of mine.
Bratton's sells the ratchet Nut Wrench for ~ $45.00. I made my own from a 1⅜" Box end wrench.
Ratchet Nut Wrench
Old 08-24-2018, 12:58 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
Put in 3rd , roll car some
Old 08-24-2018, 12:58 PM   #4
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Check that front engine mount. You engine is too high or too low.
Jacksonlll is offline   Reply With Quote
Old 08-24-2018, 01:21 PM   #5
leo
leo's Avatar
You can get a socket onto the crankshaft pulley, my socket is an S & K #40144, 1/2 drive and 1 7/8 tall, it goes over the crank ratchet easily, then if you can line up a socket extension through the crank handle hole, attach your ratchet drive handle in front of the radiator.....
leo is offline   Reply With Quote
Old 08-24-2018, 01:40 PM   #6
Rob Needs
Rob Needs's Avatar
Mine doesn't line up because the rad stone guard.
Rob Needs is offline   Reply With Quote
Old 08-24-2018, 02:00 PM   #7
Charlie Stephens
To solve the immediate problem remove the front motor mount and put a block under the engine to raise or lower it with a floor jack. Next project is to find out why the crank isn't lined up and fix it.
Remember if you go to the "roll car some" trick that you need to rotate in the direction that the engine normally runs to take up slack. If you overshoot go around again, no changing direction.
Charlie Stephens
Charlie Stephens is online now   Reply With Quote
Old 08-24-2018, 04:21 PM   #8
ahirt
It may be the crank bearing. Mine had that problem when I bought it. The crank bearing is the hole that the crank goes through. It is mounted on the front cross member beneath the radiator and held in place by the two big U-Bolts that hold the front spring on. Although the "bearing" looks the same front and back, it is in fact "sided" and can be mounted backwards. There are two protrusions on the bottom of the bearing that go into two holes on the cross member. But the protrusions ARE NOT SYMMETRICAL. They are offset to one side. Consequently, if you do not pay attention when re-assembling this, you can easily mount it incorrectly. The difference isn't much, but it is enough to prevent the crank from lining up with the crank nut. That was how I bought my car! It took me awhile to figure it out but once I reversed it, the crank lined up perfectly with the crank nut.
ahirt is offline   Reply With Quote
Old 08-24-2018, 07:19 PM   #9
Ed
If you remove the spark plugs you should be able to rotate the crankshaft by turning the fan. Use the timing pin in the front cover to find TDC.
Ed is offline   Reply With Quote
Old 08-24-2018, 07:30 PM   #10
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
X2 what Kurt said. Put the car in 3rd gear and release the ebrake. Put the timing pin in into the cam gear cover with your left hand and put pressure on it with your finger. Rock the front tire forward with your right hand and wait for the pin to drop into the cam gear dimple. You can always rock the car backwards and try again if you miss it. No need to remove the spark plugs when using this method.
Dick M is offline   Reply With Quote
Old 08-24-2018, 07:44 PM   #11
Charlie Stephens
delete, duplicate post
Old 08-24-2018, 07:45 PM   #12
Charlie Stephens
It is my understanding that you shouldn't go back if you miss the dimple. Continue around in the direction the engine normally rotates to take up the slack.
Charlie Stephens
Old 08-24-2018, 10:15 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
Charlie Stephens
I've gone back if I overshoot on the first try, but you must go back enough to go forward again enough to take up all the freeplay.
Old 08-24-2018, 10:22 PM   #14
Chris Haynes
Chris Haynes's Avatar
If the motor mount is installed backwards the engine will sit too high.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 08-24-2018, 10:23 PM   #15
J Franklin
J Franklin's Avatar
Don't turn it by the fan, fans are prone to flying apart even when they aren't manhandled trying to turn the engine.
Old 08-26-2018, 08:21 AM   #16
V4F
V4F's Avatar
not to contradict , but I turn my motor by the fan or crank nut . (2 blade aluminum)
V4f
V4F is offline   Reply With Quote
Old 08-26-2018, 11:44 AM   #17
J Franklin
J Franklin's Avatar
The aluminum fan is much stouter than a brittle original or aftermarket steel that can bend and increase flex while running and then let go through the radiator, hood or head. He should just fix the problem with being able to use the hand crank.
Old 08-26-2018, 12:44 PM   #18
ALJ
Jack up right real wheel. Put in 3rd gear. Turn wheel forward direction. If timing dimple is hard to find, pull #1 spark plug, you can see the top of the piston when it is at TDC. Make sure it is TDC on compression stroke.
ALJ is offline   Reply With Quote
