Old 04-11-2018, 08:05 PM   #1
steve40490
Default alternator wiring
I'am changing from generator to alternator on my 29 A.Does anyone have a diagram ?
steve40490 is offline   Reply With Quote
Old 04-11-2018, 08:40 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: alternator wiring
If the Alternator is 6v positive ground just disconnect your wires from the generator and connect to the alternator.
Old 04-12-2018, 09:50 AM   #3
jrelliott
jrelliott's Avatar
Are you getting a 3 wire or single wire alternator? On the single wire alternator, just connect the wires that were attached to the output of the cutout to the single output of the alternator. If it is a 3 wire alternator, send me an email to [email protected] and I will send you schematic. On the 3 wire you either have to have a fuse which you must remove when you park if for a long time or a complete cutout switch as the alternator will draw just a small amount of current even when the vehicle is turned off.
jrelliott is offline   Reply With Quote
Old 04-12-2018, 11:18 AM   #4
Bob C
6 or 12 volt?
Bob
Old 04-12-2018, 12:42 PM   #5
canadian
Hey Steve , I am in process of doing same job, question for you ? what diameter of pulley are you using? I assume you are using a 12 volt GM.
canadian is offline   Reply With Quote
Old 04-12-2018, 02:50 PM   #6
Dick Steinkamp
Dick Steinkamp's Avatar
Cars originally equipped with a 3 wire GM alternator did not have a problem with current draw when the car was turned off. You can solve this for an A by having a charge indicator light between the #1 terminal of the alternator and the battery as was done with cars originally equipped with this alternator...or, a diode in place of the indicator light.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 04-12-2018, 03:14 PM   #7
canadian
Hey Dick , just curious, if a fella just wired in a small 12 volt bulb between terminal 1 and battery connection on alternator . sort of hide it under alternator or whatever do you think this would do the trick from your experience ?
Old 04-12-2018, 03:30 PM   #8
steve40490
Thanks guys,I'am going with 6 volt pos. ground.
Old 04-12-2018, 04:45 PM   #9
Dick Steinkamp
I've done it (not on an A). Works great!
Old 04-12-2018, 05:59 PM   #10
canadian
I am actually at this task as we chat , what info can you give me on a diode? maybe easier to hide in harness.
Old 04-12-2018, 07:25 PM   #11
Dick Steinkamp
I've never done it with a diode, but this from the HAMB...
"I have always done this using the DIODE. A 12 volt (or higher) 1 amp diode works with "normal" 10si - a HIGH output alt will require a higher amperage rating - jump to a 5 amp in that case. "
https://www.jalopyjournal.com/forum/...estion.217154/
This from a tractor forum...
http://www.yesterdaystractors.com/cg...alk&th=1510639
Old 04-12-2018, 07:56 PM   #12
canadian
thanks Dick for you time and expertise .
