07-15-2016, 08:43 AM | #1 |
Next Steps
Good Morning All,
In trying to get my 1930 up and running after 30+ years I was wonder about the next logical step in getting it fired up. I have made sure the coolant system is good, pulled and cleaned out the oil pan, gave it a good degreasing, and am starting to test the fuel system. Should I try to fire it from there or go ahead and rebuild the distributer or carb or what? Not going to try and drive it till I drain, clean, and fill the transmission and rear end just fire the engine. Also the wiring is shot going to the lights and horn and need replaced. How do I test the horn before running a new harness? Excited about getting closer to waking up this car but don't want to make a wrong step. My dad, grandpa, and great-grandpa would haunt me for the rest of my life if I screw this up. Thanks, Doug
Oh Crap, he's working on the A again! |
07-15-2016, 08:51 AM | #2 |
Re: Next Steps
Did you clean out the valve chamber area? When doing that you should block the main feed holes so poop doesn't go down into them,,, pipe cleaners or such works well
07-15-2016, 08:58 AM | #3 |
Re: Next Steps
Sorry for not know all of the correct terms for things but do you mean pulling the head and cleaning? I have turned the motor and it spins free very easy but didn't think about doing that before I turned it.
07-15-2016, 09:00 AM | #4 |
Re: Next Steps
No behind the manifolds is a valve cover gasket...remove the cover and clean out any sludge in there.. As mentioned block the main oil feed holes first
07-15-2016, 09:03 AM | #5 |
Re: Next Steps
I wouldn't start replacing / rebuilding parts unless you know they are bad... I like your systematic approach.. To many don't check squat and cruise only to find out they have no oil in the trans / rear ...
07-15-2016, 09:09 AM | #6 |
Re: Next Steps
07-15-2016, 09:17 AM | #7 |
Re: Next Steps
Another thing to think about is replacing the carb gasket. It might be dry enough to let fuel leak out and down the side of the carb. As long as you are in there look around and maybe blow some air through the jets to make sure they are clear. Also take a look in the tank for rust or other crud.
Mike
07-15-2016, 09:46 AM | #8 |
Re: Next Steps
i would not start it untill you check the trans and clutch area. lots of critters like to build nests and introduce nature to the clutch area.
also the input of the trans will be spinning and id hate for the bearings/teeth to get chewed up due to no oil or get shredded from metallic debris circulating in the oil.
07-15-2016, 10:18 AM | #9 |
Re: Next Steps
"Removing a Model A from mothballs"
Lots of good info here: http://www.goldcoastmodela.com/techtips/mothballs.htm |
07-15-2016, 12:19 PM | #10 | |
Re: Next Steps
07-15-2016, 04:56 PM | #11 |
Re: Next Steps
Have a fire extinguisher or a bucket of water at first start up.
07-15-2016, 05:15 PM | #12 | |
Re: Next Steps
Relative to horn question: just attach a battery ,6v, if still that. It the horn is at all in working condition...it should make you jump Relative to bad wiring; I would not run an A with rotten wiring. If you just want the engine to run, you can rewire car first OR run new wiring in engine area only, i.e.- bat cables, coil to dist and coil to battery. With GOOD grounds a must. Most likely more Model As burned to a crisp from using with rotten wire, than any other reason, IMO. Pictures help here also. |
07-15-2016, 07:27 PM | #13 |
Re: Next Steps
Have you made any contacts in your area that you could learn from, or help you?
There should Be a local club you could join. Getting some first hand advice would help you get the rig running. I would do this before I started diving into doing too much before you learn what not to do. Bob |
07-15-2016, 07:37 PM | #14 | |
Re: Next Steps
07-16-2016, 10:11 AM | #15 | |
Re: Next Steps
07-16-2016, 11:42 AM | #16 |
Re: Next Steps
Don't be surprised if the club members check up on you.
They are probably very willing to help you. Start a journal. It is difficult after the fact to reconstruct how something came apart, what parts went where, what you did in what order. Try doing one thing at a time. Bob |
07-16-2016, 11:47 AM | #17 |
Re: Next Steps
And pictures are excellent reference. Buy a big chip. I can't do the phone thing, and don't want to learn. So I use a separate camera.
Bob |
07-16-2016, 12:51 PM | #18 | |
Re: Next Steps
I ran into the problem of not taking enough pictures so I couldn't clearly see how it all went together.
07-17-2016, 06:35 AM | #19 |
Re: Next Steps
Hardtimes is right, a new wire harness is cheap insurance compared to a fire under the car. https://www.brattons.com/30-31-one-b...g-harness.html
Model A Ford Club of New Jersey http://www.mafcnj.org Model A Pick Up Owners and Enthusiasts http://www.fordbarn.com/forum/group.php?groupid=5 |
07-17-2016, 08:20 AM | #20 |
Re: Next Steps
Dekberg,
I KNOW how sad it is to lose your DAD & all the questions you forgot to ask him. Those that still have a Dad, make a list of questions! Once, Chief, my Dad, told me of making a SEMI, out of a cut off Essex Sedan, with a Model T engine & trans, with another trans behind it!!! I asked, "What did you build the fifth wheel from"?-----"WOOD"!---I wish I had asked for a DRAWING??? Bill W.
