Old 04-18-2016, 11:31 AM   #1
rob63mess
rob63mess's Avatar
Default points gap keeps closing
Has anyone ever had a problem with their points gap repeatedly closing. After every hundred or so miles on the roadster, I have to regap the points. The car starts to run poorly and sure enough, upon investigation the points are all but closed....no where near .020. I crank the set screw as tight as I can get it but still having problems. Any thoughts? I did replace the points block.....to no avail.
rob63mess is offline   Reply With Quote
Old 04-18-2016, 11:35 AM   #2
johnbuckley
johnbuckley's Avatar
Default Re: points gap keeps closing
A new cam might help - maybe the surface is rough and wearing the points block. (a small amount of lubricant on the cam might help if you don't want to buy a new cam!)
johnbuckley is offline   Reply With Quote
Old 04-18-2016, 11:36 AM   #3
Rex_A_Lott
The rubbing block for the points cam wears. Usually pretty fast on a new set of points, after a time or two of resetting it stops wearing so fast. Good Luck
Rex_A_Lott is offline   Reply With Quote
Old 04-18-2016, 11:36 AM   #4
rob63mess
rob63mess's Avatar
thanks guys
Old 04-18-2016, 11:37 AM   #5
J Franklin
J Franklin's Avatar
Check to see if the locking mechanism on the movable point works. Make sure the cam lobes are smoothly polished, and add a bit of cam lube on the rubbing surface. You should now have located and solved your problem.
Old 04-18-2016, 11:52 AM   #6
Brentwood Bob
Try an old points stationary block.
Brentwood Bob is offline   Reply With Quote
Old 04-18-2016, 02:29 PM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Rob,
Check for a WOBBLY point arm pivot post. It can cause the rubbing block NOT to fit squarely to the cam lobe & it will wear QUICKLY! It can be tightened under the upper plate, with a TAP-TAP-TAP, from a blunt center punch & don't use a BIG HAMMER !
Bill Tap
"THE ASSISTANT GURU OF STUFF"
Old 04-18-2016, 02:35 PM   #8
Dave in MD
Two other things you may want to check. Make sure the center hole in the upper plate is tight onto the distributor housing and also make sure the two bushings or shaft are not worn.
Dave
Dave in MD is offline   Reply With Quote
Old 04-18-2016, 03:07 PM   #9
marc hildebrant
marc hildebrant's Avatar
I use dielectric grease to lubricate the cam. Did you put some lube on the cam ?
Marc
marc hildebrant is offline   Reply With Quote
Old 04-18-2016, 03:37 PM   #10
rob63mess
rob63mess's Avatar
Thanks for help. I ordered a new cam and some lube. Everything else checked out OK. Will keep everyone posted. The cam was probably original and I'm embarrassed to say that I never lubed it up.
Old 04-18-2016, 04:37 PM   #11
Mitch//pa
There you go.... The replacement cams I believe are B cams from most suppliers which will perform better..
Lube is your friend...but don't overlube it,, just a thin film on the cam... To much can get on the points contacts and create a problem like loss of spark
Old 04-18-2016, 05:03 PM   #12
chap52
chap52's Avatar
Lube the cam and a drop of non hardening loc-tite on the adjusting screw can't hurt.
chap52 is offline   Reply With Quote
Old 04-18-2016, 06:08 PM   #13
4port
4port's Avatar
I just happened to read this interesting info yesterday on point alignment. I have also put a thin layer of epoxy on the rubbing block wear surface for better wear resistance for a pitted cam.
4port is offline   Reply With Quote
Old 04-18-2016, 07:07 PM   #14
tbirdtbird
I find the best lube to be silicone grease used sparingly
'31 180A
tbirdtbird is offline   Reply With Quote
Old 04-18-2016, 08:08 PM   #15
BILL WILLIAMSON
To identify a "B" or an "A" cam: Look at the sides of the cam, a "B" cam has 4 distinct vertical "lines"---An "A" has 8 vertical sort of "lines". The "B" cam gives you INCREASED dwell angle, for a HOTTER spark.
Bill Dwell
Old 04-18-2016, 09:50 PM   #16
Tom Wesenberg
Tom Wesenberg's Avatar
Not such a big deal, but since the pivot point is also a moving part I put one drop of motor oil on it.
Old 04-19-2016, 02:38 AM   #17
Gerald1961
Gerald1961's Avatar
I had almost the same problem and found that the point adjusting screw fixation (2nd screw going into the point mounting block did not really fix on my mepro parts. I slightly deformed the threads to increase friction. Works fine and no readjustment required.
Gerald
Gerald1961 is offline   Reply With Quote
Old 04-19-2016, 05:23 AM   #18
RonC
RonC's Avatar
This is a NOS Model B distributor cam. Notice the surface has been polished after machining.
RonC is offline   Reply With Quote
Old 04-19-2016, 06:18 AM   #19
Rex_A_Lott
Carbon Paper? I cant even remember the last time I saw carbon paper.
Old 04-19-2016, 09:04 AM   #20
james hitchcock
james hitchcock's Avatar
I found the same thing happening on Ol Walter. Points were constantly closing. I found the little block that the point locking screw went through had a small crack. Each time I set the points and tightened the screw down it caused that crack to open up a bit more causing gap to drift closed. Took me forever to see the small crack. Gave me the excuse to replace with new modern upper plate.
james hitchcock is offline   Reply With Quote
Thread Tools
Display Modes
