Old 05-17-2015, 07:28 AM   #1
coop
coop's Avatar
Default 1931 Model A Ford P/U Cab Top Steel Roof Rails
I bought these are they correct for the late 31 steel top model a truck one is 3" wider both have the same dark green paint,if they are not correct for the model a what do they fit.heres a picture of what I bought
coop is offline   Reply With Quote
Old 05-17-2015, 02:21 PM   #2
SSsssteamer
SSsssteamer's Avatar
Default Re: 1931 Model A Ford P/U Cab Top Steel Roof Rails
They look like the ones used in our steel topped AA.
SSsssteamer is offline   Reply With Quote
Old 05-18-2015, 08:40 AM   #3
Bill Underwood
Those look correct without having the exact lengths. there may be other models and other dimensions that are similar but I believe those to be the ones. If so, good find as they are hard to come by. Also, they shoould be differing lengths as the cab widens to the rear.
Good luck!
BU
Bill Underwood is offline   Reply With Quote
Old 05-18-2015, 05:04 PM   #4
coop
coop's Avatar
Good luck!
BU
Bill the top one is 46 inches measuring center to center the other one measured the same way is 48 3/4 inches
Old 05-18-2015, 05:32 PM   #5
1928Fordman
1928Fordman's Avatar
I agree with Bill. They look like the correct bows for the Budd cab.
1928Fordman is offline   Reply With Quote
Old 05-18-2015, 07:35 PM   #6
Pickupman
All the information you've received from everyone is correct. Your measurements are correct. Here are a (2) pics I took of a pair that I have.
Pickupman is offline   Reply With Quote
