11-01-2014, 05:34 PM | #1 |
Expensive valve spring shims
I just saw where Speedway sells .060 valve shim set of 16 for 88.00......You can get them at NAPA for 10 bucks. Or am I missing something??
11-01-2014, 06:01 PM | #2 |
Re: Expensive valve spring shims
The NAPA shims don't say "ISKY" ??? Actually they are Hastings, so no excuses.
http://www.speedwaymotors.com/Hastin...ims,82718.html
'52 F-1, EAB flathead Last edited by Ross F-1; 11-01-2014 at 06:07 PM. |
11-01-2014, 06:07 PM | #3 |
The NAPA ones are a set of 16 at .060 ea. for $10 and the correct dia. for a flathead? If so, do you have a part number? That's about $.63 each, that sounds very cheap for that type of part.
11-01-2014, 06:08 PM | #4 |
I looked at NAPA's website and they list 50 different CompCams shims, but give no info. Prices are 75 - 90 cents each. O'Reillys sells Sealed Power shims for 29 cents each.
'52 F-1, EAB flathead |
11-01-2014, 06:13 PM | #5 |
I thought the thickness was the issue here. I have not looked at shims yet (I need to!) but most shims are thin, these are .060. Does anyone sell the .060 shims at a cheap price?
11-01-2014, 10:59 PM | #6 |
11-01-2014, 11:08 PM | #7 |
Here u go.
http://www.silver-seal.com/product/A...060-Thick.html 19.00 per 100 is that cheap enough? "LOL" R |
11-01-2014, 11:53 PM | #8 |
My extra ones are marked V.S.I. 203 on the non serriated side. I bought them a couple of years ago from a local parts store & can't find the reciept. They are approx. 1.250 od x .810 id x .060 thick. I know that they were not that expensive though. Bill
11-02-2014, 12:55 PM | #9 |
The correct spring shim number for the Flathead is "101", it may having variations in the prefix letters for different vendors.
There are A101's, B101's, and C101's. These are .060", .030", and .015" respectively. The "VSI" line would read:VSI A101, etc. We use strictly Pioneer's shims here, their numbers are A-101, B-101, and C-101. I do not purchase any "C's" anymore, really unnecessary. They should measure 1.000" O.D. and .688" I.D! These are the very same shims for the early Ford (8N) tractors. (Add) The #203 shims mentioned above here would be for a SBC, and possibly a few others! Thanks, Gary in N.Y. P.S. With respect to the extremely high pricing mentioned above I would suspect that is an error, it doesn't make any sense at all. I have no pricing available today on the Pioneer line but would figure .50/each as fair! A set of 16 should average $8.00 or so.
http://www.stromberg-bulletin.com/me...berg-equipped/ Last edited by GOSFAST; 11-02-2014 at 12:58 PM. Reason: Add info |
11-02-2014, 02:56 PM | #10 | |
06-01-2015, 06:20 PM | #11 |
06-01-2015, 06:25 PM | #12 |
Maybe the high dollar ones are hardened for high pressure racing springs to withstand valvetrain harmonics that make the springs dance around and eat soft shims.
