07-02-2014, 01:41 PM | #1 |
My recently purchased Roadster
My recently purchased Roadster that was a "Show Car" was lacking power, well over this weekend it blew a head gasket and now I know why. Every single exhaust valve was burnt, intakes were 50/50. So now I am in process of doing the valve job. Check out these pictures that are attached
Chuck McDonald, Member of AACA, Model A Club, NRA |
07-02-2014, 02:11 PM | #2 |
Re: My recently purchased Roadster
The deck doesn't look to good by the stud hole and #1 exhaust port either.
Bob |
07-02-2014, 02:17 PM | #3 |
Yes Bob I agree, has some meat on it around the combustion chamber but sparse where the bolt by the water port is.....very iffy ! a club member has the old Ford valve seat tool and after we do the seats I am going to stick with the old style valves as he also has the tool to grind the stems. Will get her running and if she holds with no leaks will drive the wheels off till whenever, if on the other hand she does not well then a new engine will be the fix. Anyway having a good time believe it or not, Oh also the head was cracked in cylinder # 4, just got a call from my machine shop.... in other words the engine was real sick.....
07-02-2014, 03:54 PM | #4 |
Yeah, those valves weren't sealing too good!
kris |
07-02-2014, 04:11 PM | #5 |
It would be best to have the block decked but it would be much more involved. A two part epoxy could be used to level up the bad spot at the water port and a composit B head gasket may have the best chance of sealing on the pitted surfaces.
07-02-2014, 06:46 PM | #6 |
07-02-2014, 09:48 PM | #7 |
Did it actually run when you got it? The compression would be horrible.
07-03-2014, 01:29 AM | #8 | |
Regardless of which head gasket you use, I'd be sure to spray copper coat on BOTH sides and then use a brush to coat around each hole. You are going to need all the help that you can get to seal compression against that block surface...good luck |
07-03-2014, 03:01 AM | #9 |
Will do and agreed will need as much help as possible with this little banger, and Russ asked if she ran, well she did ? was quiet as a mouse most likely because the valve clearance was basically zero because of wear, and I did check compression when I got her and all cylinders "Believe it or not" were at 50 + or - 3 so I knew she was not very healthy but never would I believe it to be in this condition.
Chuck McDonald, Member of AACA, Model A Club, NRA Last edited by inex01; 07-03-2014 at 04:46 AM. |
07-03-2014, 09:03 AM | #10 |
They are indeed forgiving old engines.
John |
07-03-2014, 10:45 AM | #11 |
I always use new exhaust valves when I do an engine, intake valves run much cooler but you need all the margin you can get with exhaust valves. I really do recommend the Fel-Pro brand of head gaskets, they have silicone rings around all the bolt holes ....to prevent leaks.
Joel Chester Ca. retired shop teacher |
07-03-2014, 01:23 PM | #12 | |
