Old 11-01-2016, 08:42 AM   #1
Displayman
Displayman's Avatar
Default Opinion wanted regarding painting 1947 Merc. Convert.
Curious,
I am restoring a 1947 Canadian Mercury.
Getting close to starting paint prep.
Should I leave the 2 front fenders on the Merc. for painting, or
leave them off?
Sounds like a dumb question, but I know there are people who have had experiences with both options, good and bad.
Thanks,
Bob-Hampshire, Illinois
Displayman is offline   Reply With Quote
Old 11-01-2016, 08:50 AM   #2
rockfla
rockfla's Avatar
Default Re: Opinion wanted regarding painting 1947 Merc. Convert.
Off
Old 11-01-2016, 08:52 AM   #3
Vic Piano
Vic Piano's Avatar
When ever I have had a "fat fender" vehicle painted, I've always removed the front clip, hood, rear fenders and trunk lid.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 11-01-2016, 08:58 AM   #4
TStiles
Were that beautiful Mercury mine, I'd disassemble, taking LOTS of photos along the way. Because, at my age, the photos are always handy during reassembly. Most of the horror stories I've heard come from those who are too cavalier about documenting how it came apart so when reassembly time comes, so do the problems....
TStiles is offline   Reply With Quote
Old 11-01-2016, 09:11 AM   #5
rotorwrench
rotorwrench's Avatar
Driver cars could be painted in assembled state to save time as long as there aren't rust or mounting issues (cracks, squeaks, worn or missing welt, etc.) that need attention. For full restoration, the parts need to be painted separately. It depends on what results you want.
Old 11-01-2016, 09:20 AM   #6
jagnweiner
jagnweiner's Avatar
I would vote for both front and rear off the car. Then put new fender welting on for re-assembly.
Meanwhile, as a fellow '47 Merc owner, perhaps someday I could make the 2 hr drive over to Hampshire to see your restoration?
Regards,
Scott
'47 Mercury Convertible
'25 Dodge Bros. Touring Car
'63 MG Midget
jagnweiner is offline   Reply With Quote
Old 11-01-2016, 09:25 AM   #7
51 MERC-CT
51 MERC-CT's Avatar
Back in the 1950's, when I repainted my '47 Merc. conv., it was painted while completely assembled. That was standard practice.
My current '51 Merc. was done dis-assembled.
Do it which ever way that you feel will give you the result that you will be satisfied with. You don't have to satisfy me or anyone else.
Old 11-01-2016, 09:55 AM   #8
waterboychuck
waterboychuck's Avatar
I just finished painting my 46. The front clip is off the car and the rear fenders are hanging there. Before painting the exterior of the car I did all the inside, under the hood and trunk, inside the door jams and doors. That way I could paint the car with the door closed. It worked for me and I would do the same thing again.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 11-01-2016, 03:06 PM   #9
Displayman
Displayman's Avatar
Stop by anytime.
Old 11-01-2016, 03:07 PM   #10
Displayman
Displayman's Avatar
Thanks for all the advice.
Old 11-01-2016, 08:47 PM   #11
Bill
Bill's Avatar
You mention that you are painting a 1947 Canadian Merc convertible. Is that car on the 114" frame. Can't ever recall ever seeing one on the short frame. Have seen one wagon on the 114" frame. Anyone know the production numbers for that model? Bill
Bill is offline   Reply With Quote
Old 11-02-2016, 08:05 AM   #12
Displayman
Displayman's Avatar
This Canadian Mercury is a 118" not the 114".
Bob
Old 11-02-2016, 08:30 AM   #13
GreenMonster48
GreenMonster48's Avatar
Gorgeous! What kind of paint did you use?
GreenMonster48 is offline   Reply With Quote
Old 11-02-2016, 08:56 AM   #14
trainguy
trainguy's Avatar
I prefer to remove the fenders for body work and prime coating. I paint the underside and where the fenders bolt on to the chassis,also painting the born where the fender attach. Depending if the welding gets painted,I either loosely bolt the fenders or install the welt and finish fasten the fenders then I paint the body and fenders at the same time. Using this method you avoid the color or texture mismatch you may get if you paint everything separately plus you avoid the damage to the fresh paint during assembly.
trainguy is offline   Reply With Quote
Old 11-02-2016, 10:03 AM   #15
jagnweiner
jagnweiner's Avatar
Originally Posted by Displayman View Post
Stop by anytime.
Thanks, Bob. I'll definitely try to connect sometime on in the next few months. And once yours is back on the road we can meet somewhere in the middle for a small '47 Merc convertible convention.
Regards,
Scott
'63 MG Midget
