Go Back   The Ford Barn > The Archives > Early V8
Old 03-29-2005, 10:56 PM   #1
Guest
Posts: n/a
Default sparking starter
my starter motor is giving a DEAD SHORT
39 mercury in 37 fordor
any ideas ? any way for easy removal looks complicated at my age 63 .......
need to fix it so i can get it on road.
thanx poppa joe
Old 03-30-2005, 02:34 AM   #2
Guest
Posts: n/a
Default Re: sparking starter
Poppa Joe - You're only as old as you think you are. A lot of us on this forum are at least 63 and play with these flatheads everyday. There's only 2 bolts holding the starter in place. Disconnect the positive cable from the battery first and then the starter. Unscrew the 2 bolts from the bell but don't remove them from the starter. Pull the starter to the front and down and it should pop out. You'll have more room if you remove the right front wheel but it is not necessary. Ken(SC)
Old 03-30-2005, 03:05 AM   #3
Guest
Posts: n/a
Hey Poppa Joe: 63 is not really that old!! In addition to what Ken said in his post, there may also be a small stamped steel support (if someone has not already removed and discarded) that fastens to one starter bolt and one oil pan bolt. This part usually needs to be removed. You will either need to get that old starter rebuilt/rewound or find another good new/used one. Good luck, John
Old 03-30-2005, 03:47 AM   #4
Guest
Posts: n/a
Joe: to add to Kens feedback watch out when pulling out not to pull the armature out of the case. Dave
Old 03-30-2005, 07:08 AM   #5
Guest
Posts: n/a
Hey Pappa Joe: Myself and a lot of other guys wish we were only 63. You folks in Australia are upside down from us so you are only 36. Does that make any sense?
Old 03-30-2005, 08:11 AM   #6
Guest
Posts: n/a
say it again ed. ken ct.
Old 03-30-2005, 09:11 AM   #7
Guest
Posts: n/a
Hey Ken: Old enough to have sold a decent'37 hump back sedan less engine and tranny for $150.00 which was a fair price at the time.
Old 03-30-2005, 09:21 AM   #8
Guest
Posts: n/a
You will have to lift the starter up, and tilt slightly toward the engine to clear the flywheel, then let it come down and pull it out. Careful, you don't want to drop the starter in your face young fellow.
Old 03-30-2005, 06:03 PM   #9
Guest
Posts: n/a
My Mother's 84 & still looking for a boyfriend.
At only 63 you're far too young.
Regards
Chris. NZ.
Old 03-30-2005, 06:08 PM   #10
Guest
Posts: n/a
Lawson
The major problem down here with RH drive Fords is that you have the steering column beside the starter motor.
He'll have to disconnect the steering box
from the chassis plate & at the dash then slide it out of the way enough so as to clear the starter motor.
Regards
Chris. NZ.
