Go Back   The Ford Barn > The Archives > Early V8
Old 03-29-2005, 12:52 AM   #1
Guest
Posts: n/a
Default backfire
Would timing cause couging and backfiring
when you rev the engine?
Old 03-29-2005, 01:13 AM   #2
Guest
Posts: n/a
Default Re: backfire
Yes, or carb jets too lean.
Old 03-29-2005, 01:19 AM   #3
Guest
Posts: n/a
spark plug wires crossed. Walt
Old 03-29-2005, 01:58 AM   #4
Guest
Posts: n/a
if backfiring through carb. will blow out power valve if its a 94 carb.we need more info to help. timming could cause this poorly set mix screws on carb. ken ct.
Old 03-29-2005, 03:01 AM   #5
Guest
Posts: n/a
When I was a kid, and heard a car backfire, my Dad told me that the car was running on orange juice and it was just spitting out seeds.
Old 03-29-2005, 07:57 AM   #6
Guest
Posts: n/a
Backfiring (from exhaust, not carb) in my '41 was due to crossed spark plug wires.
Old 03-29-2005, 07:59 AM   #7
Guest
Posts: n/a
slow timing, points not set correctly, crossed wires, lean mixture,,weak valve spring, check accelerator pump to see if it working
Old 03-29-2005, 11:46 AM   #8
Guest
Posts: n/a
Also could be a condensor going bad.
Butch
Old 03-29-2005, 11:52 AM   #9
Guest
Posts: n/a
Wet dist. cap, or tracking inside cap. Lots of things related to Ignit.
