Old 09-21-2017, 04:58 PM   #1
30RoadTom
30RoadTom's Avatar
Default Broke down, trans won't engage any gear....Help!
Hi folks. Shift lever seems to move ok but transmission won't engage any gears. Had not driven my '30 Roadster for 4 months. Got about 1/2 mile from home, slowing down for a stop sign, kind of heard and felt a faint pop as I clutched and down shifted into neutral. Engine continued to run fine, but no matter what gear I shifted into there's nothing there. I can move the shifter into any gear, but nothing engages. Speedometer starts to move when I lift the clutch, the higher the gear the higher the "speed" displayed. Had the car towed home. Thanks in advance for any ideas.
30RoadTom is offline   Reply With Quote
Old 09-21-2017, 05:01 PM   #2
700rpm
700rpm's Avatar
Default Re: Broke down, trans won't engage any gear....Help!
First guess: broken rear axle.
Ray Horton, Portland, OR
Old 09-21-2017, 05:02 PM   #3
30RoadTom
30RoadTom's Avatar
Thanks Ray....how would I confirm that?
Old 09-21-2017, 05:10 PM   #4
larrys40
You can see if the rear wheels pull off with the rear jacked up or if a wheel cocks off center.
With the car on the ground e-brake on you can put it in gear clutch out and feel what wheel the axle may be turning.
Sheared axle key is possible. I've had a broken axle before so know the symptoms and of course I rebuild them.
Larry
larrys40 is offline   Reply With Quote
Old 09-21-2017, 05:33 PM   #5
SeaSlugs
SeaSlugs's Avatar
if the speedo is turning the driveshaft is turning so my guess is with the others on sheared key or broken axle.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 09-21-2017, 05:43 PM   #6
Patrick L.
Patrick L.'s Avatar
Just jack the car up and turn each rear wheel to see if you feel a problem with either side.
Remove the wheel and hub. Examine the key and axle to see which is bad.
My first thought was a u-joint, but, I too think from what say its a key or axle.
Old 09-21-2017, 05:56 PM   #7
Synchro909
Synchro909's Avatar
I too think broken axle or sheared key. The latter means that the axle will be spinning inside the bub. DON"T try to drive it like this. You will only destroy the taper on the axle and in the hub, necessitating the replacement of both.
Jack up one rear wheel at a time, car in gear and handbrake off (chock the front wheels). Try turning the raised wheel. If it turns, that's the broken one.
Old 09-21-2017, 06:04 PM   #8
Marshall V. Daut
Should a broken rear axle or sheared hub key not be at fault, remove the clutch inspection cover from the top of the bellhousing and examine the clutch disk with a flashlight. If it came apart (springs and/or lining separation), you will still feel resistance as you push in the clutch pedal, but the power won't be transmitted from the engine to the transmission. This will result in the symptoms you are experiencing. The gears won't grind when you try to shift because the transmission's input shaft is not turning with the clutch pressure plate, disk and flywheel. So, you could be fooled into thinking all is o.k. inside the bellhousing. A blown clutch disk happened to me on a cross-country trip in 1974, catching me without a spare disk. It took two days in a Missouri small town to come up with a new one so that I could continue back to Arizona. Since that day, I always carry a spare disk under the seat.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 09-21-2017, 06:07 PM   #9
Bill G
Bill G's Avatar
Marshall
If the speedometer is registering, then wouldn't the output shaft of the transmission be turning?
Old 09-21-2017, 06:10 PM   #10
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
The speedo works, so the problem is in the ass end, somewhere.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-21-2017, 06:16 PM   #11
Marshall V. Daut
Yes, you are both right about the speedo working. We're back to a broken axle shaft or hub key most likely. Good catch.
Marshall
Old 09-21-2017, 07:01 PM   #12
daveymc29
daveymc29's Avatar
Could be anything to the rear of the speedometer drive gear, but nothing in front of it. Axle or shear key is the first most likely but could be the driveshaft also. Pray for a sheared key and don't test it a lot to determine what is broken, pull the hubs one at a time and hand turn them. Don't race the engine in gear and look for wobbles or whatever, you will pay for that bit of foolishness. If it's an axle, get a spring spreader before pursuing that further. Let us know what you find.
daveymc29 is offline   Reply With Quote
Old 09-21-2017, 07:21 PM   #13
700rpm
700rpm's Avatar
Bill W.
I like the way you keep things simple, Bill.
Old 09-21-2017, 07:58 PM   #14
devoreb
devoreb's Avatar
30 Road Tom
I was in Texas on a tour and the same thing happened to a guy from Nebraska. As it turned out the hub on the clutch disk separated. The clutch spun but the driveshaft wouldn't turn. We towed the car to the next town and changed the clutch disk that night ready for touring the next day. It may be your problem.
Bill
devoreb is offline   Reply With Quote
Old 09-21-2017, 08:03 PM   #15
Jacksonlll
Jacksonlll's Avatar
Be careful. When you jack up the wheel, it may come off in your hands.
Old 09-21-2017, 08:19 PM   #16
denniskliesen
denniskliesen's Avatar
I don't suppose it's possible for the driveshaft to twist off... I'd jack it up and turn one wheel and watch if the other side turns.
denniskliesen is offline   Reply With Quote
Old 09-21-2017, 08:35 PM   #17
cjkohnast
I had a broken drive shaft Just ahead of the rear end, You would think an axle would go before the the shaft,
cjkohnast is offline   Reply With Quote
Old 09-21-2017, 09:04 PM   #18
Synchro909
Synchro909's Avatar
OK, the consensus is in. Either a broken axle or the hub is loose in the axle taper. Let's wait till we hear back from the OP what he finds. (Gentle hint to the OP!!)
Old 09-21-2017, 09:13 PM   #19
Tom Endy
Tom Endy's Avatar
This was a common failure mode on a Model A with a cottage industry overdrive modification when the housing elements and the driving elements were not in alignment. One I saw, the drive stub shaft with the pinion gear on it twisted off at the front end of the locking key.
Tom Endy
Old 09-21-2017, 10:17 PM   #20
Benson
Benson's Avatar
Broken Axle keys are easy to find.
Remove both hub caps.
Put car in gear with engine running at idle.
Release clutch
Look at each axle nut.
If key is broken the axle nut will be turning.
Do not leave like this very long ... Do not want to wear out the hub and axle.
