Old 11-20-2017, 09:13 AM   #1
Tony Hillyard
Tony Hillyard's Avatar
Default Bolt size
Hello again everyone.
On my 1928 Model A Tudor the bolts where the torque tube joins the rear axle keep coming loose. I thought of fitting locking wire.
Has anyone any idea what size these bolts are? Rather than drill them for wire it might be easier (and cheaper in drills) to but some new pre-drilled ones.
Thanks in advance.
Tony Hillyard is offline   Reply With Quote
Old 11-20-2017, 10:01 AM   #2
katy
katy's Avatar
Default Re: Bolt size
3/8-24 X 3/4", Brattons 2017 catalogue page 33, P/N 6280, $6.95 per set of 6
Old 11-20-2017, 10:14 AM   #3
Tony Hillyard
Very many thanks Katy. It's much appreciated.
Old 11-20-2017, 10:33 AM   #4
Keith True
Keith True's Avatar
I think you'll find those bolts listed are for the rearmost bolts through the backing plate,not the two that go through the radius rod ends.If your bolts are loosening up you have something wrong,bad bolts,bad surface where the nut or bolt heads ride,or the E-brake carrier or the spacer under it.I think you are going to find that the whole thing has been loose for too long,and all the holes are egged out from rocking back and forth.
Keith True is offline   Reply With Quote
Old 11-20-2017, 10:51 AM   #5
Tony Hillyard
Thanks Keith True,
It was the rear ones where the torque tube fit to the rear axle. But I will double check the surfaces and the holes when I put it to pieces to replace the gasket.
Thanks to you both.
Old 11-20-2017, 12:01 PM   #6
Keith True
Keith True's Avatar
Duh,You're right.I have a loose radius rod in my mind because I have been having a go-around with somebody about one.He calls it a torque arm,and we have been exchanging a half dozen emails a day.When I read your post I thought it was him looking for another opinion on what is wrong.He doesn't want to hear what I've been telling him.He is after a magic fix,one that doesn't involve taking anything apart.
Old 11-20-2017, 07:46 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Thanks in advance.
Those 6 bolts should be drilled and wired from the factory.
Thread Tools
Display Modes
