Old 10-06-2015, 01:56 PM   #21
JAKEFORD
Default Re: Water Injection
That picture of the Air Canada Viscount brought back some memories. My first ever airplane flight was on a Vickers Viscount. Was going on a job interview. The sound of the engines made for some nice sleeping. BTW got the job offer!
This was in 1966.
JAKEFORD is offline   Reply With Quote
Old 10-06-2015, 06:56 PM   #22
rotorwrench
rotorwrench's Avatar
Water injection allowed for pulling higher temps in turbine and piston engines when using a turbo or supercharger system. The piston engines will run hotter when the manifold pressure is boosted way up and turbines engines just naturally run higher TOT or EGT when pulling extreme power levels. The water alcohol lowers the temps enough so that you can get away with the high boost pressure for a longer period of time.
In a normally aspirated engine, it will increase the density of the fuel air charge and increase efficiency of the burn. What you save in fuel mileage is partially taken by the water alcohol mix to some extent. Kind of tit for tat but if a guy wants to save every penny then what the heck. Gas is till more expensive and I'd rather we used the alcohol in this way that put it in the gas tank for sure..
