06-28-2015, 12:31 PM | #1 |
Grounds
I'm gonna add more grounds.
Based on what I read: One from battery to frame and one from engine to frame. I have two questions 1) engine to frame what bolt is best? I'd rather not use a head bolt. 2) what size cable is suggested for secondary ground? Thanks Andy |
06-28-2015, 12:43 PM | #2 |
Re: Grounds
6 volt or 12 volt?
4 doors are better than no doors! |
06-28-2015, 01:41 PM | #3 |
Re: Grounds
6 volt use 0 gauge
Thanks - 30-9 1939, 1940 Last edited by 30-9; 06-28-2015 at 01:49 PM. |
06-28-2015, 01:51 PM | #4 |
Re: Grounds
Yes 6 volts for secondary grounds can I go thinner?
06-28-2015, 06:44 PM | #5 |
Re: Grounds
The best way is to go direct to engine with ground,that is were you need the power for starter.
I have a 47 ford and I have a braided cable to body then another from body to engine head bolt. You could try the intake rear bolt. The 59a the trans is so far back the head bolt is easy. I guess the best place is down under to a trans bolt. |
06-28-2015, 07:01 PM | #6 |
Re: Grounds
That good? |
06-28-2015, 07:06 PM | #7 |
Re: Grounds
I like welding cable made up with ends; for 6 volt. Like 2/0 or 00. Local forklift place makes them up around here. Cables has more strains and is thicker then 12g. Which is the least guage for 6 volt you might want to use. 8yrs no problems for me.
Battery to frame, body connection, Frame to engine. |
06-28-2015, 07:14 PM | #8 |
Re: Grounds
Thanks Tinker!
06-28-2015, 07:55 PM | #9 |
Re: Grounds
If you would like Adileo , I can make them up for you , any lenght
06-28-2015, 08:22 PM | #10 |
Re: Grounds
Hi Andy
On my 39 Standard Coupe, which has a different battery location from yours, I have a ground from Battery to firewall, firewall to engine, and transmission to frame. The grounds have never caused any issues. Can't imagine that you need another, but you never know Jim |
06-28-2015, 08:37 PM | #11 |
Re: Grounds
Sound advise.
Thanks - 30-9 1939, 1940 Last edited by 30-9; 06-28-2015 at 08:38 PM. Reason: Wrong |
06-29-2015, 12:14 AM | #12 |
Re: Grounds
And well grounded.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
06-29-2015, 05:12 AM | #13 |
Re: Grounds
Boss - thanks for your offer, I may take you up on it. Hope to see ya soon.
Jim - That's exactly how I now have mine setup. I'm curious, do you recall what size wire you used for Tranny to frame? |
06-29-2015, 12:38 PM | #14 |
Re: Grounds
Andy
I also used welding cable and after just looking at it appears to be the same size as the battery to ground, probably 2-0 I,m sure you could use something smaller, but I had the cable, and used it |
06-29-2015, 04:28 PM | #15 |
Re: Grounds
Thanks Jim!
