03-01-2020, 07:43 PM | #1 |
Spare tire/ wheel mounting arm
Trying to remove the spare wheel mounting arms (two wheels - one each side), so the side splash pans can then, be removed ( when / after the basic body is removed).
I loosen the lower castle nuts, used penetrating oil, used propane torch and a large hammer maul ........ NG. Esther side will not budge. Are these units splined, are they a tapered wedge fit or are the keyed ? Does anyone have a suggestion? My second message try - my first note said or asked as above. The note just disappeared Dave |
03-01-2020, 09:40 PM | #2 |
Re: Spare tire/ wheel mounting arm
Mine is a smooth taper. 1930 Coupe.
03-02-2020, 11:42 AM | #3 |
