05-13-2022, 05:02 PM | #1 |
Question
Question
40 Ford Brakes everything new left rear locking up backed it off readjusted loose and still locks up put in reverse back up a touch releases Any ideas? Sent from my iPhone using Tapatalk |
05-13-2022, 05:53 PM | #2 |
Re: Question
Did you adjust your parking brake after you installed new brakes?
Be sure to read every word included here about Lockheed brakes: https://www.fordbarn.com/forum/showt...40+ford+brakes Last edited by 19Fordy; 05-13-2022 at 09:56 PM. |
05-13-2022, 05:55 PM | #3 |
Re: Question
05-13-2022, 09:50 PM | #4 |
Re: Question
Long shoe and larger dia. of wheel cylinder to the front of each wheel.
Check to make sure top of each shoe is fitted properly in the slotted piston of the wheel cylinder and that your wheel cylinder bolts are tight. Same with backing plate bolts. Are the little brass cam washers properly installed in the bottom of each shoe adjuster. I know it seems odd to ask these questions but, you never know. Go back and double check everything. You will prevail. The driver side rear should look like this. Last edited by 19Fordy; 05-13-2022 at 10:04 PM. |
05-14-2022, 12:46 AM | #5 |
Re: Question
The fact that you have to back up to unlock it makes me think the problem is in the parking brake, possibly the equalizer bar between the shoes. Make sure all that stuff is loose and not binding on the shoes. Maybe the metal on the new shoes is too thick and the shoes expand outward but then get hung up on the equalizer bar and won't return by itself. Reversing might push that shoe back in on the equalizer bar and lets the shoe return. Just for fun when it locks up set the parking brake and release it and see if that unsticks it, it might also make it worse.
05-14-2022, 06:25 AM | #6 |
Re: Question
05-14-2022, 06:28 AM | #7 |
Re: Question
Thank you for the advice
Got it back together this morning Just need to let it down and take for a ride and see what happens Thought about the e brake and will try that if it still acts up Did not find anything that jumped right out at me other the front shoe rubbing on the inside of the drum I will see what happens Sent from my iPhone using Tapatalk |
05-14-2022, 06:41 AM | #8 |
Re: Question
Good Luck Sir
05-14-2022, 07:22 AM | #9 |
Re: Question
Just got back from a little ride
Stepped down hard it wants to pull a little to the right but figure that’s in the way of the adjustment but at least they all release at this time Will do a little more this afternoon when i get time Thanks again guys Terry Sent from my iPhone using Tapatalk |
05-14-2022, 05:14 PM | #10 | |
Re: Question
05-15-2022, 04:20 AM | #11 |
Re: Question
did you replace the springs often forgotten but they do wear [loose tension] another thing is how well did you clean the drum they are porous in the surface and depending what
preservative was used on them [got some ex army drums once literally had to boil them in water to get the wax out of them ] also drum finish can have a bearing on this as they will tend to suction to the drum at the rivets [ not common but has happened more common with clutches ] |
