03-06-2022, 01:37 AM | #1 |
Pertronix coils
Hello, I have the 1942 -47 12v pertronix ignition module in my crab distributor and the 1.5 ohm internal resistor coil. It has way too much spark for ignition components to cope with.
I tried fitting another 1.5 ohm ballast to the positive lead to the coil but this caused no spark. I have another 1.5 ohm coil but if i run that I need the resistor witch will then cause no spark as it drops the voltage down to the module too low. If I run the positive lead from the distrubtor module upstream from the external ballast resistor would that cause trouble? It then would be inbtween 3 ohms. Having trouble finding a coil to match |
03-06-2022, 09:49 AM | #2 |
Re: Pertronix coils
I would call Pertronix. There tech help is very good, & I am quite certain that they will have the answer to your problem. They have always set me straight, anyways! - F F
1952 Ford F1 1965 Ford Falcon Sprint 2007 Ford Mustang GT |
03-06-2022, 01:42 PM | #3 |
Re: Pertronix coils
I sent them an email
03-06-2022, 02:39 PM | #4 |
Re: Pertronix coils
You will have better results if you call Pertronix and speak with a tech who can tell you other considerations that might be helpful. Be sure to have the part numbers of the pertronix parts you are already using.Here's the number: https://pertronixbrands.com/pages/contact-us |
