11-27-2014, 12:51 PM | #1 |
Need a brace - 8BA to BH
My truck has an 8BA/EAB Car engine in it, with an oil pan that has the three studs on the pan. I am lacking the bracket or brace that goes from the three studs to the bellhousing. I only have Truck parts books, so I don't have a way to confirm this p/n, but I believe it is 8CM-6825. I realize that is a Merc part number, but I believe I have the Merc oil pan (below). It has the internal tray.
Does anyone have a spare of this piece they would want to part with? Is that the correct P/N?
'52 F-1, EAB flathead |
11-27-2014, 01:37 PM | #2 |
Re: Need a brace - 8BA to BH
According to my Merc manual that is the correct part number. Part is listed as: Bracket assy (oil pan)-rear for 1949-51 Mercury. Also listed with part number is: Bolt (Hex Hd)-
5/16"-24 x 3/4" - brkt. to flywheel housing cover assy. You could make one without too much trouble, I think. Flat piece of steel with a 90 degree bend, kind of like an angle iron bend with a shape to fit the oil pan that you can see in the photos. Click on photo to enlarge. Last edited by 19Fordy; 11-27-2014 at 01:49 PM. |
11-27-2014, 01:41 PM | #3 |
Ross,
I don't have a spare one to sell, but there is a complete '49-'50 Merc plate now for sale on E--y. http://www.ebay.com/itm/Ford-flywhee...b8a1a3&vxp=mtr |
11-27-2014, 01:48 PM | #4 |
Thanks guys! Looking at that one on auction answers one question; the holes for the studs are slotted. I would have made one myself but I thought they would be pretty tight tolerance. Seeing that, I probably will just make one unless someone has one loose. I don't want to get into swapping the starter plate, due to my Truck/Car combination.
11-27-2014, 01:57 PM | #5 | |
11-27-2014, 02:09 PM | #6 |
I'm not sure what difference the starter plate would make, since the brace attaches to it at the rim of the BH, where all plates are essentially the same.
'52 F-1, EAB flathead Last edited by Ross F-1; 11-27-2014 at 02:29 PM. |
