Old 12-01-2021, 10:28 AM   #1
History
History's Avatar
Default Rear hub removal tool
Watched a Paul Shinn video about brakes and the fellow he had doing the brakes said he didn't like the original rear hub puller and used a "knock off" tool instead. What's your thought on this and where do you purchase the tool he uses?
Thanks
History is online now   Reply With Quote
Old 12-01-2021, 10:49 AM   #2
Will N
Will N's Avatar
Default Re: Rear hub removal tool
IMHO, the knock off tool may work on a hub that isn't on too tight, but it might lead to damaging the threaded end of the axle if you pound too much. I've used the half round pullers, and they're ok, but if you have a really stubborn hub, the right tool for the job is the KRW puller that goes all around the hub.
Will N is offline   Reply With Quote
Old 12-01-2021, 10:53 AM   #3
History
History's Avatar
Thanks for reply,,, he said that the original type could mushroom the axle end on one that was really tight. I've never removed a rear (yet) but am about to.
Old 12-01-2021, 11:31 AM   #4
katy
katy's Avatar
[QUOTE=History;2081152]What's your thought on this and where do you purchase the tool he uses? [QUOTE]
When using the "knock off" tool one should leave the selected wheel on the ground and jack up the opposite side.
Methinks that the parts vendors sell the "knock off" tool.
Old 12-01-2021, 12:22 PM   #5
CarlG
CarlG's Avatar
I have the tool made by Mitchell. It works great, and on both types of hubs.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-01-2021, 12:59 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
I'll second that. Mitchell's tool works great and unlike many hub pullers the one from Mitchell works on both types of hubs (as CarlG stated).
You can get them direct from Mitchell or from Bratton's.
https://mitchelloverdrives.com/mitchell-hub-puller/
https://www.brattons.com/UNIVERSAL-R...ductinfo/6141/
Old 12-01-2021, 01:48 PM   #7
wwirz
I used the knock off puller without incident. I think because of the mechanical advantage of this type of puller, one good blow with a carpenter hammer released the hub from the taper. When reassembling, do not use grease or oil on the taper fit
wwirz is offline   Reply With Quote
Old 12-01-2021, 02:57 PM   #8
nkaminar
nkaminar's Avatar
I have had good luck with the Universal Hub Puller, see https://www.snydersantiqueauto.com/p...6169&cat=41753. I have tried the others without good success. I bought some nuts that fit the shaft from McMaster Carr and thread them on to be flush with the end of the shaft before using the puller.
Old 12-01-2021, 03:18 PM   #9
Anteek29
Anteek29's Avatar
The Snyders Universal Hub Puller...highly recommend!
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 12-01-2021, 03:45 PM   #10
Vic in E-TN
My favorite rear hub removal tool is made by Vintage Precision in Benicia California. 800-486-0021. They also make thermostat housings.
Vic
Vic in E-TN is offline   Reply With Quote
Old 12-01-2021, 03:46 PM   #11
Y-Blockhead
Pretty sure the one Snyder's sells is the one made by Mitchell Manufacturing or is a pretty close copy. see post #6.
Old 12-01-2021, 06:51 PM   #12
Fhane
Fhane's Avatar
KRW. Works great. Tough as nails for a stubborn drum. I bought two years 40 years ago. One still in the box.
Fhane is online now   Reply With Quote
Old 12-02-2021, 10:06 AM   #13
Bob Bidonde
Bob Bidonde's Avatar
The knock-off tool may Brinnel (flat spot) the ball bearings in the differential.
Bob Bidonde
Old 12-02-2021, 10:31 AM   #14
rotorwrench
rotorwrench's Avatar
The Reproduction KR Wilson tool is a good one but is expensive by comparison to the bolt together set up. Both will get the job done.
Old 12-02-2021, 11:05 AM   #15
katy
katy's Avatar
This type works good on both types of hubs:
An old time trick was to remove the cotter pin, loosen the axle nut about 1/2 a turn or so, reinstall the cotter pin and drive around the block.
Old 12-02-2021, 11:25 AM   #16
The Master Cylinder
The Master Cylinder's Avatar
There are ball bearings in the differential? I alway thought they were tapered roller bearings.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is online now   Reply With Quote
Old 12-02-2021, 12:19 PM   #17
JKY
You are correct. When you click the instructions on the Snyder's site it opens an instruction sheet telling you it's a Mitchell. Nice stuff Mitchell makes!
JKY is offline   Reply With Quote
Old 12-02-2021, 12:53 PM   #18
CarlG
CarlG's Avatar
The one Snyder's sells IS the one Mitchell makes. The instruction sheet that they show in their "downloads" states:
This Mitchell Manufacturing product is designed to pull rear brake hubs on Ford vehicles from 1928 to 1948.
Alaskan A's
Old 12-02-2021, 05:38 PM   #19
rotorwrench
There can be problems with the bolt to the lug nut types if the taper is really tight or corroded together. The hub and drum aren't very thick like a later model vehicles after 1948 The hub & drum can be damaged or warped. Pulling from the hub nose is a safer bet. Wide 5 drums from 1936 though 39 would not work all that well either.
