07-08-2014, 11:22 AM | #1 |
Cork or felt in U-joint housing?
Just received the gasket set for the rear end and u-joint, the set came with cork instead of felt for the clamshell. Anyone have any experience using the cork? I am debating on just reusing the existing felt that is already in the clamshell vs the cork.
Trying to get the car ready for this weekend so I do not have time to wait and reorder one with felt instead. Any suggestions? Thanks! |
07-08-2014, 12:14 PM | #2 |
Re: Cork or felt in U-joint housing?
I haven't heard of cork in the clamshell. I would reuse the felt you already have installed.
Be sure to liberally grease the inside and outside of the cups. |
07-08-2014, 12:46 PM | #3 |
i have used the cork with no problem
07-08-2014, 01:36 PM | #4 |
From the '32 parts book...B-4516 (was A prefix, same part for all), "Felt (universal joint housing cap)"
Cork can be used, but is a bit of a wrestling match as you try to get it curved in two planes long enough to assemble. |
07-08-2014, 02:07 PM | #5 |
When I ordered my last such set, it came with BOTH types in same package. So, I use both. On the cork, I put in hot water to 'relax' it and use a sealant with whichever I install. Both , installed properly, work great ...JMO !
07-08-2014, 02:19 PM | #6 |
07-08-2014, 03:58 PM | #7 |
I've used both with good results
