Go Back   The Ford Barn > The Archives > Model-T
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default Electrical
I recently bought a 1923 Model T Roadster and found that the battery is installed Pos. ground. I've since bought the owner's Manual and it says Neg. ground.b Which is right?
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
Default Re: Electrical
neg ground model As are pos gnd.
Old 01-01-1970, 12:00 AM   #3
Guest
Posts: n/a
I have a 23 T, it is Neg ground
Old 01-01-1970, 12:00 AM   #4
Guest
Posts: n/a
IF you don't have a generator, OR your generator has been changed or altered in some fashion, it should be *negative* ground. In a starterless/generatorless car, it doesn't matter, as the coils and lights and horn don't care. In a car with a starter/generator, tho, it *should* be negative ground.
Old 01-01-1970, 12:00 AM   #5
Guest
Posts: n/a
is the battery 6 or 12 volt
Old 01-01-1970, 12:00 AM   #6
Guest
Posts: n/a
All Model T's were negative ground.
<ul>[*]Fun Projects Inc. Model A ,T, and V8 voltage regulators[/list]
