04-18-2024, 10:22 AM | #1 |
Door soft parts for a 39 truck
I am getting ready to redo the doors for my truck. I need to buy the rubbers and seals and what ever to finish out the doors. I want to try and get it in 1 lot not a piece from here and a piece from there. I have been looking at the online suppliers and some have kits and some I need to pick pieces off there inventory and add to cart. I really don’t know all what I need and some of the items are different on different sites. So I am looking for guidance and wisdom on what to get. Will the pickup stuff work with a truck?
I am building a 1939 1 ton express |
04-18-2024, 11:00 AM | #2 |
Re: Door soft parts for a 39 truck
The truck cab is the same as a pickup, so the rubber items will work on either body.
04-18-2024, 01:52 PM | #3 |
I wish that was true. I have learned that not everything that fits a pickup will fit a truck. I posted here in the hopes that someone with a truck has a source for the parts.
Things I know are different Firewall Entire Floor Entire back of cab Roof Back window Things I know are the same Windshield frame and associated parts Things I am about to find out Doors-I already know the glass is different
I am building a 1939 1 ton express Last edited by ActionYobbo; 04-18-2024 at 01:59 PM. |
04-19-2024, 06:58 AM | #4 |
Dennis Carpenter had a variety of NOS door window parts for the 38 and 39 commercial vehicles and trucks in their NOS department. You can try them. I do not know what they have available aftermarket. Good luck with your project.
04-20-2024, 07:52 AM | #5 | |
I think I found what I need there Their parts look correct. To what I see in my door.
04-28-2024, 07:49 AM | #6 |
The parts that go in the bottom of the door are correct. I had to drill out the tube nuts on the window frames so now I am searching for replacement screws so I can take my frames and get glass cut and installed. Some one had fun breaking every window before I got it. Edit to add: I found ford used a 6-32 tube nut on the model A and that looks like what I need and the threads are the correct size
I am building a 1939 1 ton express Last edited by ActionYobbo; 04-28-2024 at 08:12 AM. |
