Old 01-01-2021, 12:08 PM   #1
mgm60
mgm60's Avatar
Question 36 Roadster - Jack Stand locations
Learned a lesson yesterday about the flex on a Roadster frame and body. Jacked the car up and placed jack stands at either end of the frame to get access for some exhaust work and a few other things. Went to open a door and "no go". Doors on both sides out of alignment.
So what's the best location to place jack stands on a roadster and not have the frame flex so much. Location on the rear seems to be ahead of the wheels but that seems awfully far forward. Or support the rear axle instead?
mgm60 is offline   Reply With Quote
Old 01-01-2021, 12:56 PM   #2
Krylon32
Default Re: 36 Roadster - Jack Stand locations
When I jack up any old Ford I put the jack stands under the front and rear axles.
Krylon32 is offline   Reply With Quote
Old 01-01-2021, 01:27 PM   #3
DavidG
DavidG's Avatar
Nowhere except under the axles or if there's one or both axles removed, under the frame before the rear axle kick up and directly beneath the cowl.
