08-30-2018, 06:45 PM | #1 |
Working complete set or Model 'A' Shocks 7 links.
City:
Motueka
State:
Tasman
Price:
800.00
2 of the shocks are a later version (webbing on the underside) where the adjusting valve can turn completely around with no up or down movement on adjustment. Full adjustment is controlled withing 1/2 a turn of the valve nut. The other 2 shocks are earlier and have the standard adjusting valves. Also included is the arm to shock shaft mounting bolts (not pictured), an original set of body mounting bolts, nuts and washers and all grease seals and metal caps. The later show some wear. Shock bodies are marked for position on the frame. All questions answered. More pics can be shown if required.
R.H.D. Author of Model 'A' Ford technical manuals. Supplier of good original RHD parts. |
