03-18-2023, 10:57 AM | #1 |
272 assembly
i finally found a refreshed 272 and took it apart to see that its ok
my book doesn't have torque specs im installing a teflon (FEL-PRO BS 6141) main seal and it talks about rtv black and break in lub any does and don'ts appreciated |
03-18-2023, 11:29 AM | #2 |
Re: 272 assembly
The guru (referring to TED EATON) came, saw and spoketh -
https://www.eatonbalancing.com/2008/...-y-and-others/
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS Last edited by KULTULZ; 03-19-2023 at 07:26 AM. Reason: GIVING CREDIT WHERE CREDIT IS DUE |
03-18-2023, 01:26 PM | #3 |
Re: 272 assembly
This link is the rear main seal installation. If your not familiar with Ted Eaton, have a look at the whole site. There’s also John Mummert and Tim McMasters sites. Between the 3 of them (actually any one of them) there’s nothing they don’t know about Y blocks.
https://www.eatonbalancing.com/2008/...-y-and-others/ Opps, I didn’t follow K’s link far enough. My apologies. |
03-18-2023, 07:08 PM | #4 |
Re: 272 assembly
thx guy's now i just need torque specs for the rest of the engine and im good to go
03-18-2023, 07:30 PM | #5 |
Re: 272 assembly
This will get you started. From Tim McMaster’s site
http://yblockguy.com/techtips/yblocktorquetable.html See the note at the bottoms regarding the mains. |
03-18-2023, 07:45 PM | #6 |
Re: 272 assembly
https://www.amazon.com/Ford-Y-Block-...s%2C157&sr=8-1 https://www.amazon.com/Ford-Y-Block-...7938185X&psc=1 http://forums.y-blocksforever.com/de...atestPostsPage Have fun, ask questions. |
03-19-2023, 02:12 PM | #7 |
Re: 272 assembly
Should invest in a shop manual. Has the information you need.
03-19-2023, 07:52 PM | #8 |
Re: 272 assembly
The books miker mentioned are good... you might get one to double check your work before installing it in the car.
03-19-2023, 10:13 PM | #9 |
Re: 272 assembly
Try local public library.
03-20-2023, 09:27 AM | #10 |
Re: 272 assembly
i have the 1955 FORD CAR shop manual(form 7098-55) was great when i did timing chain on my last Y block
i haven't found general engine torque spec in it yet??? you provided link to eaton , very helpfull thx |
03-20-2023, 03:45 PM | #11 |
Re: 272 assembly
In the 56 Shop Manual, torque specs are in the back. 55 different ?
03-21-2023, 08:05 AM | #12 |
Re: 272 assembly
I have found the 1954-55 Ford Truck Shop Manual to be lacking in many torque specs. My go-to source is the 1959 Ford Truck Shop Manual. Page 1-106 has a fairly complete table. It also provides a table of torque by bolt size. So if you are holding a 5/16-24 bolt you know its max torque is 15-18 ft-lbs, for example.
I think if you get a little bit newer manual and pretend you have a 292 you'll be in good shape.
Allen '55 F100 with slightly newer 292 Y-block find the detailed project story at https://www.ford-trucks.com/forums/1...o-project.html |
03-21-2023, 09:11 AM | #13 |
Re: 272 assembly
i got the torque specs from eaton thx
??? my solid lifters are water stained on the top and i can feel it with my finger nail , is that going to eat my cam??? thx |
03-21-2023, 10:16 AM | #14 |
Re: 272 assembly
If I could feel the wear/rust with my fingernail I'd replace them. Are the lifters & cam new or used?
It might work out better to replace the cam & lifters with a new matched set. Use a good assembly lube and a high-zinc break-in motor oil. |
