12-25-2021, 04:58 PM | #1 |
New guy with a project Model AA
Greetings,
Been lurking for a while as a guest and joined now that I have a project to start. 1931 Model AA, plan is to start a full restoration in the coming weeks and hopefully do everything myself (or at least attempt). Vehicle appears mostly complete, motor doesn't run but turns over without issue. Excited to get this AA back on the road. |
12-25-2021, 06:07 PM | #2 |
Re: New guy with a project Model AA
Great project . Photo shows steering tube in need of repair. See Restorer issue Jan/Feb 2021 for an excellent guide to repair. Worked beautifully for me.
12-25-2021, 06:37 PM | #3 |
Welcome to the Barn. You’ll find all sorts of fine help here. Enjoy your truck! :-)
Sent from my iPhone using Tapatalk |
12-25-2021, 07:01 PM | #4 | |
Thanks for the repair info, that is the exact reason I'm here . I've already learned a bunch and will likely be overwhelmed in no time. |
12-25-2021, 07:07 PM | #5 |
Nice ride. Enjoy!!
12-25-2021, 07:38 PM | #6 |
12-25-2021, 08:11 PM | #7 |
Usafexplorer,
Great looking truck. What is the tube coming off the oil fill tube going towards the back of the engine? The body looks real good and the truck looks complete. Have fun with your new project too! Regards, Chris
1932 AAB Truck 1953 Ford Jubilee 2015 Ford F250 SuperCrew Lots of Allis tractors Some Cub Cadets |
12-25-2021, 08:18 PM | #8 |
[QUOTE=sugarmaker;2088658]Usafexplorer,
Great looking truck. What is the tube coming off the oil fill tube going towards the back of the engine? Functions as PCV. There is one on my 30 coupe |
12-25-2021, 08:54 PM | #9 |
Is that an indented firewall? Does it also have a steel top? It looks like it's in pretty good shape.
Red |
12-25-2021, 09:00 PM | #10 | |
12-25-2021, 09:09 PM | #11 | |
Yes, indented firewall. The top looks like it has been replaced, some kind of cloth/fiberglass type material. Overall in good shape, last on the road in '78 so its been sitting around while. Fortunately its been stored inside the last 40 years or so. |
12-26-2021, 01:01 AM | #12 |
It is a flexible road draft tube , keeps the engine compartment cleaner. I run mine behind the starter, make it a bit neater.
12-26-2021, 02:32 PM | #13 |
Great looking truck you got there. Don’t forget to get the Les Andrews books and join up with a club.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
12-26-2021, 09:29 PM | #14 |
12-27-2021, 04:43 PM | #15 |
Great project, I had a late 31 AA with the solid metal roof.
12-28-2021, 04:29 PM | #16 |
12-28-2021, 07:51 PM | #17 |
Was finally able to look at the pics on a computer screen vs. my phone. I do hope you are going to rewire the truck. If not you may have a wieny roast on your hands.
Curious what you did in the AF? Mike
12-28-2021, 07:53 PM | #18 | |
Worked on F-16's as a crew chief for about 14 years, forced into a retrain once we lost our aircraft. |
12-29-2021, 07:34 AM | #19 |
I know you will be very tempted to start the engine ,most folk do . You must remove the oilpan and pop out the dipper tray and clean out all the sludge and clean the pump gauze filter screen . Remove the timing chest cover and clean out the valve chest the main bearings are fed from 3 holes in the floor of the chest one each end and one in the middle .If the holes are blocked the crank bearings will fail .
John in West Drayton London England . |
12-29-2021, 08:59 AM | #20 |
I saw that one for sale and considered it for a bit. Glad you got it. I probably have enough for awhile.....maybe.....
