09-19-2018, 03:48 PM | #1 |
Too Tall Coil
I’ve been troubleshooting my rough running issue (https://www.fordbarn.com/forum/showthread.php?t=247907) and was isolating on the coil. I found that a rebuilt coil I had was sitting too tall on the distributor causing the fan blades to hit it! I thought the generator/fan had slipped and, therefore, reset the generator. Still hits.
The middle coil is a Ford script coil; the one on the left is stamped “Standard” and both fit without issue. The too tall coil is not marked on top but has SME stamped on the underside. Have never seen this issue reported or discussed here. Has anyone else encountered this problem?
Kerry |
09-19-2018, 04:06 PM | #2 |
Re: Too Tall Coil
Slightly longer fan belt??
09-19-2018, 05:24 PM | #3 |
Re: Too Tall Coil
Is this for the car in your avatar? If so, I'd suggest you install the correct distributor along with the correct coil...that would be the easiest way.
Or, a longer belt as has been suggested.
09-19-2018, 05:51 PM | #4 |
Re: Too Tall Coil
I think there were two types in 1936. The early one was the dome top from 34 to 36. The later one was a flat top & had two screws If remember correctly. It seems they were different from the 37 to 41 set up too. A lot of them had the dome top and would have no trouble with clearance. A person just needs to know what they have.
If that car has a 1937 engine, the distributor may have followed it along. Last edited by rotorwrench; 09-19-2018 at 05:56 PM. |
09-19-2018, 07:53 PM | #5 | |
Re: Too Tall Coil
The coils shown belong to the 37 - 41 group. They are slightly taller than the 36 coil(s). I do know from personally experience that a 37 - 41 dizzy and coil will fit on a 36. What I don't know, is of they will fit with a correct 36 belt. I'd suggested going to the authentic dizzy and coil as I prefer to do things correctly.
09-19-2018, 10:07 PM | #6 |
Re: Too Tall Coil
32 motors had a real tall coil that looked like a ridiculous conehead. Don't think that transferred over to 33's but maybe. Twice what you have pictured in height. You're built coil may just need a longer belt, if you have a pocket to run it in. Last edited by Tinker; 09-19-2018 at 11:07 PM. |
09-19-2018, 11:06 PM | #7 | |
Re: Too Tall Coil
09-19-2018, 11:10 PM | #8 |
Re: Too Tall Coil
John I've only seen pictures, but that is what I understand the late 36 flat type looked like. Thank you for adding. Very interesting about the angle of the machine screws.
09-20-2018, 04:23 AM | #9 |
Re: Too Tall Coil
A 36 fan will hit the 37 coil. The 37 fan, whilst a bigger dia than 36, has different shaped blades to clear the taller coil.
09-20-2018, 04:48 AM | #10 |
Re: Too Tall Coil
No room for a 37 fan in a 36 if all is stock.37 Fan hub is about 2"
09-20-2018, 08:11 AM | #11 |
Re: Too Tall Coil
Wouldn't having the current coil rebuilt be an easy solution?
09-20-2018, 01:08 PM | #12 |
Re: Too Tall Coil
'No room for a 37 fan in a 36 if all is stock'
Exactly my point, so by running a 36 fan, you'll get contact!!
09-20-2018, 01:36 PM | #13 |
Re: Too Tall Coil
I'd go for the earlier dome type distributor if one is available anywhere. Find one with an good coil & have it rebuilt. It would look more at home in a 36 even with a 37 block with the water pump block off plates. The 37 & 38 21-stud engines were pretty adaptable. Definitely the best of the 21-stud motors in my opinion.
09-20-2018, 02:23 PM | #14 | |
Re: Too Tall Coil
rebuilt for you or someone else. You may be able to swap it out with him. G.M.
www.fordcollector.com |
09-22-2018, 02:44 PM | #15 |
Re: Too Tall Coil
First of all, I should have mentioned that the car/engine in question is a 36 Cabriolet with a 37 engine. (It was stated in my referenced post and I did not think to re-state it…my mistake.) It is all stock for 36 except the engine and block- off plates. Sorry for all the diversion regarding the correct distributor/coil and fan blade.
Rotorwrench is correct…the distributor and coil were in the car when it was purchased 20 years ago. And it has run this way ever since… except for a failed coil about 5 years ago. I believe this distributor/coil combination would be correct for the engine. I don’t have much room for a larger fan belt as there is about 1″ clearance in the radiator dimple. I will send the suspect coils to Skip for rebuild (one has been rebuilt previously). I am also looking for suitable replacements. So far I have only seen 1 of the taller coils. The SME coil is stamped not etched on the underside. I have 2 questions: 1. Am I the only owner of a 36 car with a 37 engine who has observed this issue? 2. If I would change to a shorter style coil, what can I use? Thanks…
Kerry |
09-22-2018, 07:38 PM | #16 | |
Re: Too Tall Coil
The shortest coil out there is the "flat top" 36 style. You'd need the respective distributor as well. You might check with George Haney as he may very well have one completed and ready to ship.
09-22-2018, 07:45 PM | #17 |
Re: Too Tall Coil
Kube said:
"Kerry, The shortest coil out there is the "flat top" 36 style. You'd need the respective distributor as well. You might check with George Haney as he may very well have one completed and ready to ship." George "Ship" Haney > 941-637-6698 or 941-505-9085 > email [email protected]
09-23-2018, 12:23 AM | #18 |
Re: Too Tall Coil
After reading your post #15 ,what intake manifold do you have on the engine ? If its a '37 the generator mounts lower.If that is the case replacing it with a 35-36 with a higher gen mount could solve the problem.Here is a pic of a 37 intake.
09-24-2018, 12:31 PM | #19 |
Re: Too Tall Coil
The intake is a 36 aluminum manifold and, as you are aware, the generator mount is higher than a 37 CI intake. At one time I thought of installing a 37 intake but realized that the fan would be a problem hitting the coil. So would need to replace the fan or distributor/coil. Decided to keep it as it is.
Kerry |
09-24-2018, 02:01 PM | #20 |
Re: Too Tall Coil
You could put in a remote coil adapter .
