11-05-2017, 06:12 PM | #1 |
39 master cyl
Is there anything that holds the brake pedal push rod in the master cyl. I am replacing the master cylinder. Pulled like crazy cant get it to come out. I know some new ones have a clip that holds rod in not sure about this one. don't see anything on parts brake down. Thanks Doug
Doug |
11-05-2017, 06:23 PM | #2 |
Re: 39 master cyl
should not be any clip, is the master cylinder/rod out of the car?, if so pull the boot off and look inside if not just pull harder to see if it is the rod or the boot holding it in. just did a 39 coupe without too many problems
11-05-2017, 06:25 PM | #3 |
Re: 39 master cyl
As I recall; there is a wide snap ring on the rod, and no way to get at it. I used a lots of thin lube, and a strong 'wiggle' pull to jerk the rod out. Newc
11-05-2017, 06:45 PM | #4 |
Re: 39 master cyl
Doug |
