03-16-2022, 09:00 PM | #1 |
Mercury Crankshaft Plug
Hi All,
Looking to replace the sludge clean-out plugs in 49-50 Mercury crankshaft. Anyone have a source for these replacement plugs? Thanks, Steve |
03-16-2022, 09:09 PM | #2 |
Re: Mercury Crankshaft Plug
Replacing the plugs with the original type press in plugs is not the best idea. Since they only press in the can actually leak.
The best thing to do it tap the hole for a tapered plug or a straight thread using a thread sealer. Which way is best depends on the hole diameter. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
03-16-2022, 10:46 PM | #3 |
The plugs are Dorman 555-010.
03-16-2022, 10:52 PM | #4 |
Summit racing sells a alum.pipe plug.1/2 in i think takes allen head, you dont have to drill the hole just run pipe tap down hole.Cliff.
03-18-2022, 10:36 AM | #5 |
I'm right there with my merc crank, back from the machine shop. I like the aluminum pipe plugs because I don't want to get it balanced and of course the weight of plugs is a concern. Glad I saw this, thanks.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
03-19-2022, 11:28 AM | #6 |
The crank ahd ONE hole 1/4" in dia on the front counterweight about 1/4" deep. The rear had the same. The flywheel had one 1/2 dia hole 1/4" deep. all this cost over 300 bucks and for a street engine, that might hit 4K once in a while, I just don't see the point. However, 300 dollars is not a large amt of money in this day and age, and many can afford it. Some of us can't. I have to save my money now th have the cylinders bored and pistons fitted.. Need a set of Qa1 14: shock s if anybody has any laying around. Gramps |
