Old 11-28-2013, 10:48 PM   #1
Herman Munster
Herman Munster's Avatar
Default 1956 Ford Front License Plate Bracket
I've been trying to find a front plate bracket for my '56 Fairlane but haven't had any luck. Is there any sources for them?
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic
Herman Munster is offline   Reply With Quote
Old 12-08-2013, 08:59 PM   #2
THRASHER
THRASHER's Avatar
Default Re: 1956 Ford Front License Plate Bracket
I need one (or more) as well ..
Any luck locating these yet ???
THRASHER is offline   Reply With Quote
Old 12-08-2013, 09:09 PM   #3
Herman Munster
No. I'm still looking for leads. There's a possibility that one from a '59 might work.
Old 12-09-2013, 11:20 PM   #4
alt63bird
They had brackets? I thought the slotted holes in the bumper eliminated the need for brackets.
Alan H. Tast AIA, LEED AP BD+C
Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI)
http://www.vintagethunderbirdclub.net
Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years"
35+ year member, Crown Victoria Ass'n.
alt63bird is offline   Reply With Quote
Old 12-09-2013, 11:22 PM   #5
Herman Munster
I'm pretty sure they did. The front plate bends when mounting straight to the bumper.
Old 12-10-2013, 12:17 AM   #6
Y-Blockhead
Y-Blockhead's Avatar
I'm wondering if you could just fab a couple of spacers for the bolts to pass thru just thick enough so the plate mounts straight?
Old 12-10-2013, 10:13 AM   #7
Ole Don
Ole Don's Avatar
I used one inch long one inch diameter rubber bumpers between the plate and the bumper. The plate stays straight, and when bugs hit, it gives just a little.
Ole Don is offline   Reply With Quote
Old 12-10-2013, 05:18 PM   #8
Daves55Sedan
Daves55Sedan's Avatar
Never seen one that had a bracket on the front, but it would be pretty easy to rig something up with spacers if you don't want you license plate bent around that curve.
Old 12-10-2013, 09:48 PM   #9
Herman Munster
I was thinking about fabbing something but I didn't want to mickymouse something on a car that is mostly original. There is a listing for one in the Ford parts book but there is no illustration.
I just want to do things right.
Old 12-11-2013, 03:04 PM   #10
raceron1120
raceron1120's Avatar
What base # did you find in the book for the front bracket? I didn't see it listed for a '56. I'm thinking it would be 17A385 but it's not in my '49-'59 book.
raceron1120 is offline   Reply With Quote
Old 12-11-2013, 03:59 PM   #11
Herman Munster
I don't have the book in front of me but I think it was 17736. 17A385 looks like a newer number.
Old 12-11-2013, 04:36 PM   #12
Y-Blockhead
17A385 is a generic part # for a Ford license plate bracket. Just about every Ford bracket on ebay has 17A385 in it, for example; XL3Z-17A385-AA is for a 2002 Ford Expedition license plate bracket.
Are there any other numbers with it like B5A-17A385?
Old 12-11-2013, 05:37 PM   #13
raceron1120
I'm aware of Ford's part numbering system and their base #s - it's one of the first things I learned when working Ford Parts Departments and why I said it. No, there isn't a B5A license bracket listed in the 1964 edition '49-'59 book I have.
But once in awhile those Ford folks will toss a zinger # in that's not the same or common base part #, and one has to scramble to find it.
Base #s 17244 and 17736 are also front license plate mounting brackets; there may be others as well. The B7A-17244-A so is for a '57. The other one I found has 3 apps - B5S-17736-A ('55-'56 Bird), B8S-A ('58 Bird) and B9A-A ('59 full size).
Old 12-11-2013, 10:36 PM   #14
Herman Munster
I've searched the web for many of those part numbers but the only ones that ever come up are for Birds.
Old 12-21-2013, 03:09 PM   #15
smtichy
smtichy's Avatar
Hi Herman,
I stumbled across one about 2 months ago, but didn't tag the site. I will research and see if I can find it. It was really simple, a strip of metal, with ends bent up at 90 degree angles and a single hole in the angled section. In the main part of the strip were holes to mount it to the slots in the bumper.
Makes me crazy I can't find the site, I want to contribute and return all the good advice everyone's given me.
Steve
'55 Sunliner - 292 V8, 3 speed man. w/ OD
ČKMAA - Český klub majitelů amerických automobilů
smtichy is offline   Reply With Quote
Old 12-21-2013, 03:27 PM   #16
Herman Munster
That would be great Steve. Try looking in your internet browser's history. If you use Firefox, it can be fairly easy.
Old 12-21-2013, 04:07 PM   #17
smtichy
smtichy's Avatar
Hi Herman,
I do use Firefox, but I have 3 computers, and a tablet so its a little tough to research the history.
Anyway I found something here similar to what I was looking at before, but the site refers to it as 57-59. But I swear I found the same part referring to a 55-56.
http://www.fordrestorationandparts.c...-plate-bracket
Let me know if you've already come across this and ruled it out as not original.
Steve
Steve
Old 12-21-2013, 04:56 PM   #18
Herman Munster
Thanks but yes I have come across this before. I felt the asking price was a bit much for a simple rusty piece of metal.
Old 12-22-2013, 11:06 AM   #19
smtichy
smtichy's Avatar
Hi Herman,
Do you know if that part is the same as the original bracket from a '55 - '56? As I'm also trying to figure out what the correct design is.
Steve
Steve
Old 12-22-2013, 11:36 AM   #20
Herman Munster
I'm not sure. I've never seen what an original bracket looks like.
