Old 12-08-2017, 11:06 AM   #1
W1964
Default Light Switch 1939 Coupe
In the process of changing wiring harness and light switch at lower end of steering column. The old wires and switch at this juncture are covered in oil. What’s the problem here?
Related question-Are the push-on connectors on the new harness sufficient to keep wires in place or should they be soldered?
Thanks for your response. Bill
W1964 is offline   Reply With Quote
Old 12-08-2017, 11:14 AM   #2
Kube
Kube's Avatar
Default Re: Light Switch 1939 Coupe
Oil is from a leaking steering gear box.
I always solder wires for best contact / continuity. I suggest you do the same.
Especially if you do not intend to fix the leak.
Old 12-08-2017, 11:17 AM   #3
40cpe
40cpe's Avatar
The most likely cause of the oil in the light switch is a broken brass tube attached to the bottom cover of the gearbox. The tube extends above the oil level and is there for the horn wire to run through. With the switch removed you will see four bolts holding the square end cover on. Remove the four bolts and pull straight away from the box. The brass tube (if still attached) will pull out of the steering shaft with the cover. Be sure to preserve the gaskets on the cover as they are shims to adjust gear box gearings. If the brass tube isn't attached to the cover you will have to fish it out of the shaft. If you find this is the problem, come back for repair info.
I don't know the pros and cons of the connectors.
