11-29-2022, 09:27 PM | #1 |
U-Joint Housing early Ford V-8
Did all 32, 33, and 34 Fords utilize the same 32-48 style 3-piece clamshell U-Joint covers? Or was there an alternative single-piece design off the assembly line that eventually phased out?
11-29-2022, 09:35 PM | #2 |
Re: U-Joint Housing early Ford V-8
The 32's used a one-piece design, while the later cars used a two-piece design. I believe my 34's had the two-piece clamshell . . . but I can't tell you exactly when the change was made.
11-29-2022, 09:36 PM | #3 |
One piece up to 35 I believe.
11-29-2022, 10:43 PM | #4 |
One piece 32-34
11-29-2022, 10:54 PM | #5 |
Yep, one-piece from Job #1 in March, 1932 through the '34 model year.
11-29-2022, 11:22 PM | #6 |
11-29-2022, 11:33 PM | #7 |
The correct early design, I assume?
11-29-2022, 11:59 PM | #8 |
11-30-2022, 12:47 AM | #9 |
up to 35...not thru 35 !! picking nits
12-01-2022, 02:15 PM | #10 |
12-01-2022, 02:17 PM | #11 |
12-01-2022, 05:54 PM | #12 |
Originally made of cork, but a lot easier to install the felt variety offered by thirdgenauto.com.
12-02-2022, 12:24 AM | #13 |
There is another variation of one piece clamshell.
Pictured one has grease fitting mid point. I have some like that but also some with grease fitting at 5 oclock. The level of fluid with factory 4oz spec is 5 oclock Always thought the lower fitting was earlier . DavidG would be good to listen to on stuff like this |
