Old 02-22-2022, 05:45 AM   #1
HotRodmicky
HotRodmicky's Avatar
Default How to get a 1932 steering wheel of the column?
Hi, i have pretty stuck steering wheel i like to take of the shaft.
Cant use heat ...
I soaked it in wd40 etc and tried with a puller, but stopped as i am afraid to
Break the bakelite /plastik
Steering wheel is in very good condition...
Any Ideas?
Regards
Michael
HotRodmicky is offline   Reply With Quote
Old 02-22-2022, 05:58 AM   #2
mercman from oz
mercman from oz's Avatar
Default Re: How to get a 1932 steering wheel of the column?
HotRodmicky, you need a tool like this - Winfield Tool Works VZ194 Steering Wheel Puller
Old 02-22-2022, 07:55 AM   #3
jimTN
Screw a axle knocker on the shaft, get a big hammer, put both knees under the wheel, push up and whack the axle knocker.
jimTN is offline   Reply With Quote
Old 02-22-2022, 08:21 AM   #4
Tim Ayers
Before getting a vintage Snap On wheel puller, I've done it two ways:
Drilled and tapped into the steering wheel hub which allows you to use a modern type puller.
Second way was to use a large bearing separator under the wheel and used that as a puller.
Old 02-23-2022, 07:49 AM   #5
HotRodmicky
Hi,
Thank you for your Ideas.
After i saw the pic of the puller, i got the idea for a thick rubber Ring!
Aircooled vw rear torsion bar rubber!
I will try that with a bearing separator , i guess
Thanks again
Old 02-23-2022, 01:29 PM   #6
325w
Try Kroil it works better than WD
325w is offline   Reply With Quote
Old 02-24-2022, 10:08 AM   #7
Andy
I use a bearing separator from HF. I put it under the wheel with some cloth padding and use a two jaw puller. It works just like the Ford tool. I have never damaged anything doing it this way. I also have bought tools and taken them back.
Andy is offline   Reply With Quote
Old 02-24-2022, 11:35 AM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
I've removed some steering wheels that were really stuck fast to the shaft taper. Whatever type of puller you decide to use, make sure you have something resilient or some type of padding on the back of the wheel hub, and something on the threaded end of the shaft to keep it from mushrooming or otherwise damaging the end of the shaft. I usually back the hex nut off untill it's even with the top of the shaft, and then place a small piece of flat stock on top of the nut to press against. I would also NOT recommend hammering in anyway on the threaded end of shaft, nor on the back of wheel at the hub. The KRW style puller is the best, but in my desperation to remove a wheel with no puller available, I made my own which has worked well for me and some of my friends.
John
Old 02-24-2022, 11:43 AM   #9
JM 35 Sedan
Cant use heat ...
Any Ideas?
Regards
Michael
WD-40 is really not a good lubricant nor penetrant, and it can ruin some plastics. It was originally developed as a water displacement.
John
Old 02-25-2022, 07:22 AM   #10
HotRodmicky
I also used other lubricants then wd-40 ... i just dont want list them all,
And you USA guys dont know the name of german products anyway :-)
I will try it later today , and will report :-)
Thanks
Old 02-25-2022, 09:26 AM   #11
Tim Ayers
https://www.ebay.com/itm/16535056497...IAAOSwniliFSvb
Keep your eyes peeled for this tool. This one is missing the rubber protection on the yoke but some rubber hose will fix that. As mentioned, when needed, its a real time saver.
Old 02-25-2022, 11:38 AM   #12
deuce_roadster
deuce_roadster's Avatar
I have a KRW steering wheel puller, If I didn't, I would drill and tap 2 holes likes suggested above and make a pin to go into the shaft like in the picture of the Winfield copy has to prevent damaging the threads by mushrooming the top of the shaft and use a modern puller. Under no circumstance would I put anything on the shaft to hit it with a hammer. I am not sure when Ford started putting threaded holes in the steering wheels but I think up to maybe 39 they have that tapered part where it meets the mast jacket.
Old 02-26-2022, 02:34 AM   #13
HotRodmicky
I tried i yesterday without luck.....
Someone else before me hit the shaft with a hammer so the threads are not in good condition anyways. That i can fix once i have the steering wheel of the shaft.
I try to avoid to drill the steering wheel....
It is a german Bosch 1932 Ford Coachbuild steering wheel !
I rather cut the the steering box shaft off and drill/ream the shaft out of the wheel
The hole assembly is in such a good condition...
Still looking for.Ideas
Old 02-26-2022, 04:18 AM   #14
mercman from oz
This is the Snap-On CG-60 Steering Wheel Puller sold on eBay that Tim Ayers mentioned.
Old 02-26-2022, 03:42 PM   #15
38 coupe
38 coupe's Avatar
I have been told that you can put padding behind the clam shells from the front of a torque tube then use a modern bearing puller under that. I haven't tried yet, that happens next weekend on a friend's 36.
