Old 01-01-2021, 09:27 PM   #1
Fairlane500
Fairlane500's Avatar
Default New pinion bearings
Hello,
I purchased a set of pinion bearings and it came with this spacer that goes between the races. Original doesn’t have this.
Is this an update that you just tighten to spec and it’s a preset dimension that’s good to go?
If you have experience with this I would like to hear from you your thoughts and experiences.
Regards
John
File Type: jpeg 65C2C8CD-2160-4798-A2AF-BD43C40413DD.jpeg (170.8 KB, 66 views)
Life is not a dress rehearsal...
Fairlane500 is offline   Reply With Quote
Old 01-01-2021, 09:49 PM   #2
Will D
Will D's Avatar
Default Re: New pinion bearings
Just for packaging?? Where did you get the bearings from?
What year rear are you rebuilding?
That piece was not with my new bearings and race when I recently rebuilt rear on my '38.
Will D is offline   Reply With Quote
Old 01-01-2021, 09:56 PM   #3
Lawrie
Lawrie's Avatar
From experience,PAY particular attention to the brand of the bearings.if no brand,DONT use them .I will only use NOS ford ones or a recognised brand ,timken etc. some times I put. a spacer in-between the bearings ,BUT its a fiddly job to get the preload right with a spacer.
Lawrie
Old 01-01-2021, 11:19 PM   #4
Brian
Brian's Avatar
I'd NOT use the spacer; you set the preload through tightening up the two nuts with interposed tab washer. Agree with what Lawrie says above
Brian is online now   Reply With Quote
Old 01-01-2021, 11:21 PM   #5
Brian
Brian's Avatar
It's a fiddly job even without the spacer!!!
Old 01-01-2021, 11:23 PM   #6
Brian
Brian's Avatar
Incidently, it's easier to set the preload on the side bearings prior to doing the pinion preload, as then you're not dealing with the additional friction from pinion set up.
Old 01-01-2021, 11:38 PM   #7
Will D
Will D's Avatar
Follow this great advice from Brian! Makes a big difference.
Old 01-02-2021, 12:21 AM   #8
Fairlane500
Bearing has 799082D number on them
Rear axle is 1934 Ford
Old 01-02-2021, 01:31 AM   #9
Lawrie
Lawrie's Avatar
Fred (barnfind08 ) has NOS ford bearings,
Lawrie
Old 01-02-2021, 02:15 AM   #10
deuce lover
deuce lover's Avatar
Here is a pic of an extra set I just sold ,all NOS. Bearings are Bower which was a vendor for Ford.
Old 01-02-2021, 05:00 AM   #11
Fairlane500
Thank you for the replies to date, I have messaged Fred @Lawrie
Old 01-02-2021, 09:48 AM   #12
deuce lover
If your double cone race is not USA marked I would be wary also.Its actually harder to find than the bearings.18-4616 is the Ford part number.
Old 01-02-2021, 10:19 AM   #13
Charlie ny
VanPelt is an excellent source....do not forget the axle seals and premium gasket sets,
VP has them as well.
Charlie ny
Old 01-03-2021, 03:23 AM   #14
Fairlane500
Charlie ny
Thanks Charlie, I have converted it to 9 Inch Dutchman 28 spline Axles and spider gears so all good in that department. Just need pinion and carrier bearings.
Old 01-03-2021, 03:24 AM   #15
Fairlane500
Thank you, John
Old 01-03-2021, 05:59 AM   #16
PeteVS
PeteVS's Avatar
A bunch of years ago, I rebuilt a banjo rear with new bearings AND a new ring and pinion. I had a hell of a time getting the preload on the pinion bearings. The preload would be too loose, I'd tighten the nut and the outer pinion would jump a bit and the preload would then be too tight. Over and over again. I finally got it good. It turns out that the pinion shaft was the same diameter full length and both bearings were fairly tight press fit. That shaft should have been a schosh looser for the outer bearing so wouldn't have taken so much force to move it to the proper preload point. Next time, I'll take a wee bit off that outer end of the shaft if it's the same diameter full length.
Old 01-03-2021, 01:50 PM   #17
bobH
Originally Posted by PeteVS View Post
A bunch of years ago, I rebuilt a banjo rear with new bearings AND a new ring and pinion. I had a hell of a time getting the preload on the pinion bearings. The preload would be too loose, I'd tighten the nut and the outer pinion would jump a bit and the preload would then be too tight. Over and over again. I finally got it good. It turns out that the pinion shaft was the same diameter full length and both bearings were fairly tight press fit. That shaft should have bee a schosh looser for the outer bearing so wouldn't have taken so much force to move it to the proper preload point. Next time, I'll take a wee bit off that outer end of the shaft if it's the same diameter full length.
Original pinion shafts came with that step on them. The pinion shaft you describe, is what I would call a defective part. The guy that has 'moded' pinion shafts for me, is a flathead guy, and a crankshaft grinder. He knows this stuff, and simply duplicates what Henry did in the first place. Next time you have an original 30's pinion in hand, measure the shaft.... easy to measure the 'step'.
bobH is offline   Reply With Quote
